tshep
As above, these have a metal, odd shaped thing that says Kubota BX and is ribbed.
Others do not.
What is it, which section of part book?
Others do not.
Yepp!You are referring to this correct? View attachment 3419177
My weight broke off its mounts early. The tractor works fine without it. Over 2Khrs at this point.Yeah, it's just a chunk of cast iron.
Full power mowing work, with some lugging down. Also a plugging fuel filter slow to be identified. It was running fine and smooth when I heard such a clatter. One of the suspension struts (leftward) holding the weight fatigued and broke right at the point it was bolted to the weight. I unbolted the right side from its strut and removed the weight. I have never detected any ill effects. Its just as smooth at mid to full rpm, and with ~20# off of a high front location Ill even bet the tractor is a little more stable on side slopes. "FREE MONEY"Wow, that's surprising, if I recall they are bolted to the exhaust manifold along with some other brackets.
Did you do a lot of low idling?
