BX1500 item under hood?
   / BX1500 item under hood? #1
tshep
Gold Member
Richmond, VA
BX23 MLB
As above, these have a metal, odd shaped thing that says Kubota BX and is ribbed.
Others do not.
What is it, which section of part book?
You have a picture of what you are talking about?
I found out it was a cover for a balancer (for the 2 cyl) some sort of geared/chained weight.
Still looking for it in the parts book.
   / BX1500 item under hood? #4
It is just a chunk of metal bolted to the engine to help with vibration/harmonics of the 2cylinder engine. I couldn't find it in the parts book either.
My dad has a 1500 and I was curious about that weight also when he bought it.
It really doesn't even rotate?
Just mass?
   / BX1500 item under hood? #6
You are referring to this correct?
   / BX1500 item under hood? #8
Yeah, it's just a chunk of cast iron.
   / BX1500 item under hood? #9
My weight broke off its mounts early. The tractor works fine without it. Over 2Khrs at this point.
   / BX1500 item under hood? #10
Wow, that's surprising, if I recall they are bolted to the exhaust manifold along with some other brackets.
Did you do a lot of low idling?
UNUSED FUTURE 350 HYD BREAKER HAMMER (A52706)
UNUSED FUTURE 350...
2023 Bobcat T770 (A60462)
2023 Bobcat T770...
2019 MACK GRANITE (A58214)
2019 MACK GRANITE...
2023 Ford Expedition SUV (A59231)
2023 Ford...
2015 Haulotte 5533A (A53316)
2015 Haulotte...
2019 MACK PINNACLE (A55745)
2019 MACK PINNACLE...
