BX1500 item under hood?
   / BX1500 item under hood? #1
tshep
Richmond, VA
BX23 MLB
As above, these have a metal, odd shaped thing that says Kubota BX and is ribbed.
Others do not.
What is it, which section of part book?
You have a picture of what you are talking about?
I found out it was a cover for a balancer (for the 2 cyl) some sort of geared/chained weight.
Still looking for it in the parts book.
   / BX1500 item under hood? #4
It is just a chunk of metal bolted to the engine to help with vibration/harmonics of the 2cylinder engine. I couldn't find it in the parts book either.
My dad has a 1500 and I was curious about that weight also when he bought it.
It really doesn't even rotate?
Just mass?
   / BX1500 item under hood? #6
You are referring to this correct?
   / BX1500 item under hood? #8
Yeah, it's just a chunk of cast iron.
   / BX1500 item under hood? #9
My weight broke off its mounts early. The tractor works fine without it. Over 2Khrs at this point.
   / BX1500 item under hood? #10
Wow, that's surprising, if I recall they are bolted to the exhaust manifold along with some other brackets.
Did you do a lot of low idling?
2016 Ford Explorer AWD SUV (A55853)
2016 Ford Explorer...
2018 MDB T5E MDB DISC MOWER (A51247)
2018 MDB T5E MDB...
2012 Club Car Carryall 1 Utility Cart (A54811)
2012 Club Car...
Kuhns AE10 Small Square Bale Accumulator - 10-Bale Efficient Handling System (A55301)
Kuhns AE10 Small...
40' CONTAINER (A52706)
2022 John Deere 1023E MFWD Compact Utility Tractor with 120R Front Loader (A55314)
2022 John Deere...
