BX1500 item under hood?
/ BX1500 item under hood? #1
tshep
Richmond, VA
BX23 MLB
As above, these have a metal, odd shaped thing that says Kubota BX and is ribbed.
Others do not.
What is it, which section of part book?
You have a picture of what you are talking about?
I found out it was a cover for a balancer (for the 2 cyl) some sort of geared/chained weight.
Still looking for it in the parts book.
/ BX1500 item under hood? #4
It is just a chunk of metal bolted to the engine to help with vibration/harmonics of the 2cylinder engine. I couldn't find it in the parts book either.
My dad has a 1500 and I was curious about that weight also when he bought it.
It really doesn't even rotate?
Just mass?
/ BX1500 item under hood? #6
You are referring to this correct?
/ BX1500 item under hood? #8
Yeah, it's just a chunk of cast iron.
/ BX1500 item under hood? #9
My weight broke off its mounts early. The tractor works fine without it. Over 2Khrs at this point.
/ BX1500 item under hood? #10
Wow, that's surprising, if I recall they are bolted to the exhaust manifold along with some other brackets.
Did you do a lot of low idling?
/ BX1500 item under hood? #11
Full power mowing work, with some lugging down. Also a plugging fuel filter slow to be identified. It was running fine and smooth when I heard such a clatter. One of the suspension struts (leftward) holding the weight fatigued and broke right at the point it was bolted to the weight. I unbolted the right side from its strut and removed the weight. I have never detected any ill effects. Its just as smooth at mid to full rpm, and with ~20# off of a high front location Ill even bet the tractor is a little more stable on side slopes. "FREE MONEY" ;)
UNKNOWN TANK MANIFOLD (A58214)
UNKNOWN TANK...
2006 INTERNATIONAL 7400 6X4 DUMP TRUCK (A52706)
2006 INTERNATIONAL...
TOOTHED BUCKET FOR MINI EXCAVATOR (A58214)
TOOTHED BUCKET FOR...
RAKE ATTACHMENT FOR MINI EXCAVATOR (A58214)
RAKE ATTACHMENT...
(160) PIECES OF 1"X6"X6' WHITE PINE TONGUE&GROOVE (A60432)
(160) PIECES OF...
