BX1500 item under hood?
   / BX1500 item under hood? #1
tshep
Richmond, VA
BX23 MLB
As above, these have a metal, odd shaped thing that says Kubota BX and is ribbed.
Others do not.
What is it, which section of part book?
You have a picture of what you are talking about?
I found out it was a cover for a balancer (for the 2 cyl) some sort of geared/chained weight.
Still looking for it in the parts book.
   / BX1500 item under hood? #4
It is just a chunk of metal bolted to the engine to help with vibration/harmonics of the 2cylinder engine. I couldn't find it in the parts book either.
My dad has a 1500 and I was curious about that weight also when he bought it.
It really doesn't even rotate?
Just mass?
   / BX1500 item under hood? #6
You are referring to this correct?
   / BX1500 item under hood? #8
Yeah, it's just a chunk of cast iron.
   / BX1500 item under hood? #9
My weight broke off its mounts early. The tractor works fine without it. Over 2Khrs at this point.
   / BX1500 item under hood? #10
Wow, that's surprising, if I recall they are bolted to the exhaust manifold along with some other brackets.
Did you do a lot of low idling?
FUEL TANK W/2 STANDS (A55745)
FUEL TANK W/2...
2012 FREIGHTLINER M2 106 (A55745)
2012 FREIGHTLINER...
1999 MACK RD688S MIXER TRUCK (A55745)
1999 MACK RD688S...
EZ-GO Utility Cart (A55853)
EZ-GO Utility Cart...
2013 Vermeer V800G T/A Towable Vacuum Trailer (A53421)
2013 Vermeer V800G...
Ford Super Duty Pickup Truck Bed (A51691)
Ford Super Duty...
