BX 25 in 10ft dump trailer??
/ BX 25 in 10ft dump trailer?? #61
And if the tongue on the lightweight 2000# rated trailer is designed to carry 1000# rather than the normal tongue weight of 200-400# for a trailer that size... Aaron Z
minor detail... I will say that I don't drive behind any trailer anymore unless I absolutely have to and I keep a distance. Just didn't realize how many folks haven't a clue how close they are to converting to darwinism.
/ BX 25 in 10ft dump trailer?? #64
I'll be sure to let everyone know when my tires melt off from overloading, my wheel studs all simultaneously sheer off causing my tractor to summer salt over the roof of my truck. Until then I will keep my 8 grand in my pocket
/ BX 25 in 10ft dump trailer?? #65
OK, I did die, and went to heaven, and St. Peter sent me back with a new trailer... and a new truck!:cool2:
18' long, two 3500 lb. axles with brakes on both, and lovely ramps that slide into their own compartments underneath the trailer. Cost: $3K.
My old 5 X 10 trailer is so jealous!:(
/ BX 25 in 10ft dump trailer?? #66
Good idea. You might need it to pay the fines and medical bills.
/ BX 25 in 10ft dump trailer?? #68
You were about 20 minutes from me if you got that right from bluewater
/ BX 25 in 10ft dump trailer?? #69
Good idea, that $8k might pay for the first few days of legal fees if you're involved in an accident that harms someone knowing and admitting here you trailered illegally without regard for public safety. Hopefully my daughters and family are not on the same roads you drive.
/ BX 25 in 10ft dump trailer?? #70
And we're done. You're obviously are the smartest man alive and everyone else is wrong. :duh:
/ BX 25 in 10ft dump trailer?? #71
The safety police sure is giving you a hard time. Maybe it is because you have a Yanmar ;)
/ BX 25 in 10ft dump trailer?? #73
No pic, But I put my BX24 in my 6X10 dump trailer with no problems, just hang the FEL over the front, in fact I don't even strap it down since it holds itself in place by doing this.
Who am I to judge but I make sure mine is chained down. I don't like straps on equipment. Chains and load binders work well and it's not going anywhere when they are one four corners.
/ BX 25 in 10ft dump trailer?? #74
Hey- nice that 4shorts is back posting!
When my newish L3400 came home from Maryland's Eastern Shore on New Year's Day (105 miles, more or less) my buddy hauled it for me. He has a good, big trailer with 2 axles with brakes, ramps (aluminum ramps he had a boat welder make for him, since the steel ramps were killing his back), etc., just like check's. I was impressed. He carefully X chained it in the back, then pulled it forward and chained the front with load binders after wrapping some special nylon straps over the front axle... I don't know much about trailering, having only a 4x8 little one good for a 1000 lbs, if that, and no truck these days. He explained what he was doing and why, and went on to tell me about a friend of his who was hauling a tractor he owned, got stopped by the state police for something, and when he gave the cop a smart answer, the cop got out his rule book and went to the trailer and truck rig. When he was done, the guy had over a $1000 worth of infractions written up.
Like on of the other posters, I tend to avoid traveling behind trailers, and will often look at how they've secured their loads when I pass them. Often not good. In fact, I wish the cops would pull more of them over when they obviously are a danger.
/ BX 25 in 10ft dump trailer?? #75
Let's do some math for all the lawsuit fearing Americans on here to try to put them at ease
yanmar tlb approx 2700 lbs
5x10 trailer made of 3 inch c channel and 2x3 tubing,
12 inch 10 ply tires rated at 1550 a piece
inproper 4 bolt wheels rated at 1250(5 lug are 1550)
sheer strength of a 1/2 bolt? 14,000 lbs
axle was built with smaller hubs so we could keep our tires but they put a bigger pipe in it not sure of the rating on the pipe
So yes, I know the trailer is overloaded with the tractor on it but unfortunatly I don't have the huge pockets everyone else does to spend 7 grand on a dump trailer I have no other use for.
This year the tractor has gone 25 km to my dad's work to dig out some fence post and 15 km the other way to plant 30 cedar trees at my cousins house. I take my time, drive the speed limit and I'm on back roads not the long island expressway doing 85 mph. It is strapped down also to avoid the dreaded summer salt over the hood of the truck killing a school yard full of children
so in closing, yes its illegal , yes its overweight.
are the wheel studs going to snap ? no.
are the tires going to melt off? I doubt it
am I going to rear end a bus full of schoolchildren? in a full size truck with 4 wheel disk brakes, doubt it
am I glad I live in canada? ugh..ya
/ BX 25 in 10ft dump trailer?? #76
Guess I'm not posting pics of my setup when I trailer the tractor anywhere! :eek:
/ BX 25 in 10ft dump trailer?? #78
My soul is too delicate, I couldn't handle the abuse.
/ BX 25 in 10ft dump trailer?? #80
not something I'd want to post on a public forum.
2007 MACK GRANITE CV713 DUMP TRUCK (A60430)
2007 MACK GRANITE...
2008 Ford Fusion SE Sedan (A59231)
2008 Ford Fusion...
2012 GENIE Z45/25J ELECTRIC BOOM LIFT (A60429)
2012 GENIE Z45/25J...
12 X 20 CAR PORT (A58214)
12 X 20 CAR PORT...
2018 New Holland C227 Compact Track Loader (A61306)
2018 New Holland...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
