BX 2350
/ BX 2350 #1
Will Schafer
Anderson, Texas
Kubota BX 2350
My BX2350 (430 hrs) has intermittent power problems - usually when mowing and after warm , it looses power and revs and "lugs down" seems to be getting worse -
Ive changed both fuel filters with no relief. Im in process of draining fuel. I will also change out the fuel pump.
1) how do I get any potential trash / crud out of the fuel tank / lines after draining ?
2) any ideas - ? am I on the right track ?
/ BX 2350 #2
What about trying an off the shelf Diesel Fuel System treatment? I haven't tried one on my BX but has fixed weird issues on my truck several times.
/ BX 2350 #3
Two things, there could be something plugging the outlet to your fuel tank. I remember one person who had a large leaf that would plug his fuel tank, then float away and work for a while. Some BX owners have also found a rusty fuel sending unit that will plug the fuel filters quickly.
Another thing is there is a small lift pump on BX's. It almost looks like a small fuel filter but it metal instead. These have been know to fail. You should hear it clicking if you turn the key on but don't start it.
As a rule, the fuel filters on the BX series suck. A lot of people either swap a fuel filter set up from a B series Kubota on them or use a Racor brand fuel filter setup. I installed a Racor on mine and eliminated the rear fuel filter and it stopped mine from plugging up. Before I installed the Racor setup, mine would plug up but usually just in the winter.
/ BX 2350
it certainly is a "weird issue" youre right on that - I'll try the treatment when I replace the fuel this weekend - thanks
/ BX 2350
thanks Dave - Im putting in a new fuel pump this weekend - tell me a little more about the Racor brand filter setup? is there a model number you used?
/ BX 2350 #7
Don't have time for a full answer now, but the Racor replaces the rear filter. Do a search and you can find some threads with pics.
REDDICK 3PT SPRAYER (A63290)
REDDICK 3PT...
2016 Etnyre Falcon Live Bottom Trailer (A62613)
2016 Etnyre Falcon...
207272 (A52708)
207272 (A52708)
2003 KAUFMAN 29' GOOSENECK TRAILER (A63290)
2003 KAUFMAN 29'...
FEED TANK (A63290)
FEED TANK (A63290)
2017 FREIGHTLINER CASCADIA 125 6X4 T/A SLEEPER TRUCK TRACTOR (A59911)
2017 FREIGHTLINER...
