BX 23 FEL Float problem
/ BX 23 FEL Float problem #1
BRIGUY
Glenville NY (Land of High Taxes)
BX 23, Wheelhorse 312-8
I'm having a problem with the 4 way valve on my FEL. The float detent has disappeared and the hydraulic operation has become irratic.
After a quick call to the dealer He seemed to know what the problem was. He is ordering a part for the detent. (spring loaded piece???) I'm going to drop off the valve for repair when the part comes in.
Has any one else had this problem?
Did I do anything wrong?
I have done a lot of pulling with the bucket hooks.
/ BX 23 FEL Float problem #2
I did lost my float possition for a while, it kept pop back to neutral. My oneman dealership came to my house and found some ice(winter time) inside the groove causes it to pop out.
My Bx also have some othe issue but not terrably bad yet.
Alex
/ BX 23 FEL Float problem #3
My BX2230 lost the float with 10 hours on it. It happened in the winter but it wasn't the reason. Your dealer is correct. The detent is spring loaded which causes anything in the fluid to make it fail. The reason I was told was there was a few metal shavings in the cylinder making the detent stay open so the joystick would pop back to neutral. After they fixed it the float worked very smoothly for me. I believe it came from the factory that way and now it's much better.
You didn't do anything wrong but their excuse is a little funny. Either way their fixing it so it shouldn't be a problem. Pulling doesn't matter
/ BX 23 FEL Float problem #4
My float just stopped working on my BX yesterday.
Did you guys determine the spring for the detent broke?
If I get a chance tomorrow, I'll pull the loader console apart and see what I find.
My problem isn't resolved yet. The dealer ordered the kit to fix the float detent and the wrong kit was sent. The dealer caught this before mine was taken apart so I wasn't inconvenienced in any way. (GOOD DEALER) Seems that there is two or three types of valves used on these loaders over the past few years. After checking my serial # the correct part was ordered. In the process of all this my detent started working again after being inop for over a month. I checked and the correct part was in but the manager who takes care of me was going to be on vacation for two weeks. Returning 9/1, so sense the detent is working again (FOR NOW) I decided to wait For him to come back just to simplify things.
/ BX 23 FEL Float problem #6
That seems odd. What would cause it to stop working and then start working again.
It must not be a spring like detent that I am use to seeing on old cars.
I looked at http://www.tractorsmart.com/Books/bx23.htm for the parts list and I didn't recognize any parts that looked like a spring loaded detent.
Do you know what the part number is?
/ BX 23 FEL Float problem #7
My guess is that it is a small chip or piece of dirt that blocks a port and then finally moves on to be caught in the filter. This foreign object might be a result of poor cleaning in the manufacturing process of the valve. Seems like all these occurrences happen when the tractors are relatively new and then we don't hear about them in later life.
/ BX 23 FEL Float problem #8
You may be correct. I have 30+ hours on my BX now.
I talked to one of the mechanics at the dealer to get advice on me doing my 50 hour service, and he told me that chips could be the cause, but that a few times he has seen parts (not in the hydro circuit) to get rusty and bind up. He said he takes the mechanism apart and packs then with water proof grease and the problem goes away. He does use new parts to assemble them.
One funny thing, he asked me if the tractor has been wet? I replied that other than washing it a few times and getting caught in the rain on my way back to the garage NO. Plus I always blow it off with the leaf blower to dry it off. He said that with the way the valves are dry assembled that could do it, and packing it with grease will fix it. So I asked then why was it left outside for a month before I purchased it????
I'm not knocking the mechanic. On the contrary This guy is good I have seen his work (CLEAN!!!!!!) I am confident that his fix will work.
The BX 23 operation manual page 81 states " Also, lubricate joints of control lever linkage". I still haven't figured this out yet. To my knowlegge the Shop Manual for the BX 23 is still unavailable.
/ BX 23 FEL Float problem #10
BRIGUY --I spray my FEL and BH linkages with synthetic silicone spray. It make sthe linkages move much smoother.
GSXR
Thanks for the tip. I'll try that. What do you use?? Triflow, Superlube, or something else. I don't want to creat a dirt magnet.
O/K guys here is the answer to my FEL float detent problem. I forgot to update this post a few weeks ago but I've been spending wayyyyyy to much time at work.
Jim at Emerichs didn't want to tie my machine up so he told me to wait until I didn't need the loader for a few days, and then to drop off the 4 way valve.
The problem was water in the valve no parts required. It was taken apart, cleaned, and then packed with grease. It is a closed unit so the water does not come from rain or washing the tractor. The mechanic thinks condensation forms on the inside of the valve during the heat up and cool down cycle. It's filled with grease now so condensation can't form. Works better than ever. The mechanic told me that Kubota will probably be putting out a TSB on this.
Here again having a great dealer makes all the difference in the world. I dropped the valve off in the morning (before they were open) and it was ready that day. A valve kit had been ordered ahead of time. If it had needed parts that they didn't have in stock they would have had them shipped overnight.
Great Service Thanks to every one at Emerichs
/ BX 23 FEL Float problem #13
I use Amsoil synthetic silicone spray on the linkages but any silicone should work. I know my BH controls are a lot easier.
6ft. 3pt. Blade (A65640)
6ft. 3pt. Blade...
2013 FORD E-350 11 PASSENGER VAN (A65643)
2013 FORD E-350 11...
Iranch IRGC40 (A64127)
Wolverine TL-12-72W 72" Skid Steer Tiller (A62679)
Wolverine...
Lincoln Electric Shield-Arc SAE-400 - Radiator Missing - For Parts or Rebuild (A63689)
Lincoln Electric...
2018 FORD F-350 (A65643)
2018 FORD F-350...
