buying a tractor
/ buying a tractor #11
I own a TroyBilt 10HP Chipper/Shredder and an 18HP HydroStatic lawn tractor. The chipper/shredder kept slipping the belt from the time I bought it until the dealer noticed that the idler assembly was on completely backwards (from the factory). It developed stress-cracks in the flange weld of two different in-feed chutes. They replaced them under warranty, but I gave up and had it welded with some reinforcements and it has held up fine since. The bearings went out - lots of labor to replace. Another weld broke. If finally threw a rod (I'll take credit for that - worked it hard) and now here I am with Elly May and Sally.
A weld that attaches the steering link plate to the front axle broke on the lawn tractor. A couple of pulleys have died on the mower deck. Something is always breaking on the mower deck. I got tired of the down time and aggravation with this one and bought a ZTR. Since its worth almost nothing, I kept it around to pull the cart and fertilizer spreader (and as a backup in case the ZTR breaks).
The chipper was pretty poor at chipping, but the shredder worked well. I keep thinking about buying another engine and using it for fall cleanup. The dealer I bought my ZTR from also carries Troybilt and he recommended that I not do this. Apparently the Troybilt chipper line has been orphaned and you can't get any parts for them anymore.
/ buying a tractor #12
The chipper I have is a Yard Machine. It works great for what it was intended: shredding leaves and yard debris into mulch. It will chew up branches from a fallen tree, but it is rather time consuming. I prefer using a 3PT PTO chipper for that.
2015 GMC Savana 2500 Cargo Van (A59230)
2015 GMC Savana...
2019 KUBOTA U35-4 EXCAVATOR (A52706)
2019 KUBOTA U35-4...
2013 Dodge Durango (A53317)
2013 Dodge Durango...
Challenger MT275B 40HP 4WD Utility Tractor w/ 76in. Rotary Brush Cutter Attachment (A59228)
Challenger MT275B...
2021 MULTIQUIP WHISPER PORTABLE AC GENERATOR (A59823)
2021 MULTIQUIP...
2014 Chevrolet Silverado (A60352)
2014 Chevrolet...
