Built a new log lift
   / Built a new log lift #1
Window Geek
Central Mass.
2006 Kubota 7610 HST 4WD
Built a new log lifter for handling the big stuff and loading it onto my wagon or splitter. It's built out of scrap 3" channel, with one bolt and a little left-over chain. Most of my logs cut to 20" so I built this to pick up 22" and less. With another hole drilled for the pivot, I can always adjust it for bigger logs. I did the welds with my little Campbell wire welder.
Other pics available at Paul Weisblatt's Photos - Getting in the firewood | Facebook
   / Built a new log lift #2
nice set of tongs. However, maybe you could put some teeth on bottom of the c channel to build in a safety factor for a better bite ? I bet that if you tried to pick up a frozen log, with snow/ice it will slide right off.
Thanks Radioman. Yup. I ground 3 teeth on all 4 edges of the channel to increase the bite. :)
   / Built a new log lift #4
Window Geek,
I just sent you a PM about you front auxiliary light.
1449 (A57192)
1449 (A57192)
WATER TRAILER (A58214)
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
8065 (A55852)
8065 (A55852)
2023 Kubota L6060HST Compact Utility Tractor (A61307)
2023 Kubota...
2025 BOBCAT ZT7000 MOWER (A59905)
2025 BOBCAT ZT7000...
