Built a new log lift
   / Built a new log lift #1
Window Geek
Central Mass.
2006 Kubota 7610 HST 4WD
Built a new log lifter for handling the big stuff and loading it onto my wagon or splitter. It's built out of scrap 3" channel, with one bolt and a little left-over chain. Most of my logs cut to 20" so I built this to pick up 22" and less. With another hole drilled for the pivot, I can always adjust it for bigger logs. I did the welds with my little Campbell wire welder.
Other pics available at Paul Weisblatt's Photos - Getting in the firewood | Facebook
   / Built a new log lift #2
nice set of tongs. However, maybe you could put some teeth on bottom of the c channel to build in a safety factor for a better bite ? I bet that if you tried to pick up a frozen log, with snow/ice it will slide right off.
Thanks Radioman. Yup. I ground 3 teeth on all 4 edges of the channel to increase the bite. :)
   / Built a new log lift #4
Window Geek,
I just sent you a PM about you front auxiliary light.
2020 KENWORTH T680 SLEEPER (A59904)
2020 KENWORTH T680...
CATERPILLAR 627K SCRAPER (A52707)
CATERPILLAR 627K...
ANTHONY CARTS 94LFW-24 OXY/ACCELYNE TANK CART (A60432)
ANTHONY CARTS...
KIVEL 48" PALLET FORKS 3500 LB CAP (A60430)
KIVEL 48" PALLET...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2018 Toyota C-HR SUV (A59231)
2018 Toyota C-HR...
