Built a new log lift
/ Built a new log lift #1
Window Geek
Central Mass.
2006 Kubota 7610 HST 4WD
Built a new log lifter for handling the big stuff and loading it onto my wagon or splitter. It's built out of scrap 3" channel, with one bolt and a little left-over chain. Most of my logs cut to 20" so I built this to pick up 22" and less. With another hole drilled for the pivot, I can always adjust it for bigger logs. I did the welds with my little Campbell wire welder.
Other pics available at Paul Weisblatt's Photos - Getting in the firewood | Facebook
/ Built a new log lift #2
nice set of tongs. However, maybe you could put some teeth on bottom of the c channel to build in a safety factor for a better bite ? I bet that if you tried to pick up a frozen log, with snow/ice it will slide right off.
Thanks Radioman. Yup. I ground 3 teeth on all 4 edges of the channel to increase the bite. :)
/ Built a new log lift #4
Window Geek,
I just sent you a PM about you front auxiliary light.
2006 Cadillac GM Superior Coach 6-Door Limousine - Only 21,567 Miles (A63689)
2006 Cadillac GM...
LONG PTO 5" X 6" IRRIGATION PUMP (A64278)
LONG PTO 5" X 6"...
(2) CHROME STEP BARS (A64276)
(2) CHROME STEP...
2019 Ford F-550 4x4 Altec AT40G 40ft. Insulated Bucket Truck (A64556)
2019 Ford F-550...
John Deere Sign (A64557)
John Deere Sign...
2001 JOHN DEERE 310SG BACKHOE (A63276)
2001 JOHN DEERE...
