Building a Greenhouse
/ Building a Greenhouse #1
pajoube
Montana (Near Bozeman)
Former Owner PowerTrac 425 (September 2003)
One of our local garden supply growers went out of business and put on the market over 100 greenhouses for sale. You had the choice of 48 feet up to 200 feet long and they would assist you in breaking down. We ended up with a 48-foot by 30-foot unit, which included fans, watering system, tables, and heater. We elected to decline the tables, watering system, and heater.
The following photos show the progression of building this greenhouse and the methods we used. Space was a factor in getting the smaller unit as well as cost.
There are many online sources for greenhouse materials such as film, supplies, or complete units. We were very pleased with our choices and the finished product.
PJ
Used a sod cutter to open up area for greenhouse, which will be 30 by 48.
PJ
Drilled holes 30 inches deep, 4 feet apart for the 2 inch pipe.
PJ
Used plum line to get 2 in pipe about level. Did not cement in each pipe.
PJ
Redwood full length ties the pipes together and is also used to staple the cover secure.
PJ
Put a square pipe on my boom pole to extend its reach. Worked very well as I had a bent piece of metal on end to secure ribs while lifting.
PJ
The width is 30 feet. The ribs are just a little longer so must be pushed toward center to place in the 2 pipe. The rib material is 1 3/4 inch. Has tapperd ends.
PJ
Put 4 x 4's into ground about 18 inches. Again no cement was used.
PJ
Putting the side rails on. Each 4-foot span is bolted to side rail then attached to the end 4 x 4's.
PJ
All ribs and ends are completed.
PJ
Plywood puzzle.
PJ
Ready for fans and doors.
PJ
First 48 inch fan in place.
PJ
What it looks like from the outside.
PJ
All in place.
PJ
Ready for doors.
PJ
Barn door type going in.
PJ
Ready for the other end. Top will be wire mesh on frames for summer and covered in winter.
PJ
Trenched underground water into greenhouse.
PJ
52 x 52 6 mil greenhouse film carried out of garage to driveway.
PJ
