Building a flatbed for my F350
   / Building a flatbed for my F350
If you're using PT, a lot of the modern treatments promote rust like crazy.
On the last project like that I did, I used rubberized roll flashing like they use on doors and windows to put under wherever the boards would touch. Time will tell if it actually helps or just eases my conscience, but I rest better knowing it is there...
Good info, thx
   / Building a flatbed for my F350 #62
I'm planning on using quarter sawn southern yellow pine on my pending truck bed that will have limited outdoor exposure. Maybe I'll paint it if need be.
A few years ago I used quarter sawn southern yellow pine on an outdoor picnic table that was blasted with rain and sun and cold and after several years it looked great. All I put on it was a sloppy mix of 60% paint thinner mixed with 40% real varnish once a year. I planned to paint it but it never needed it so I figure if it worked for a picnic table it will work for a show truck/light work bed. Does this sound OK?
   / Building a flatbed for my F350 #63
TSO - looking great.
Mine is a F250, would not want to do without the dump. I use it for 1 1/2 tons gravel, firewood, mulch, firewood, more firewood. It is my only truck, gets used for everything. No 4 wheel tractor, no big equipment, so being able to dump a yard of material is worth it to me.
That is a very nice looking bed. How much heavier than the stock bed?
I use my F350 routinely for gravel and mulch and have found that the Loadhandler type belt and crank works great
Works even better when my son provides the power:)
I ended up buying the additional pad so it slides off even easier.
   / Building a flatbed for my F350 #64
Then I guess you should have shown us a pic of your F350
   / Building a flatbed for my F350 #65
The second pic shows the rear of my F350 after a partial unload.
Do you need complete diagrams?
The first pic was from the link I gave.
What difference does the pic make?
My point was that although a dump is often desirable, for the small loads (< 3,000lbs) there is another inexpensive alternative for rather easy unloading with some muscle.
We unloaded about 5 "bedfuls" of mulch, sand, gravel manually with a shovel before I bought the HF load handler and I was surprised the load handler would work so well.
   / Building a flatbed for my F350 #66
No, I don't need complete diagrams. Its just that anyone looking at the pic directly under your wording (without clicking on the link) seems to indicate you were posting a pic of your truck and son powering it. I had no reason to check the link so guessed it was your pic as I'm sure many others probably did.
No insult intended and I'm sure those loadhandlers do a great job and your point well taken.
   / Building a flatbed for my F350 #67
The picture Newbury posted is fine. Why would anyone care who is in the picture or who's truck it is?
Now just looking at the picture it would seem that if you walk the load to the tail gate it would be a disaster for the truck bed and tail gate. Just my thoughts.
Some updates...
Here's the solution to re-locating the fuel-fill neck. I mounted it thru the side-rail, and the cap sits flush with the outside of the rail.
Also finished the bulkhead. Added a few bungee and cargo strap holes. I'm not going to cage the rear window. I'd rather have access to it in case of needed repairs/replacement, and available for exit/entry (if needed).
Then finished up by reinforcing the fifth-wheel-rail welds and adding gussets to the C-channel near the rails attachment points.
So, construction is complete. Just have a few holes to drill for wiring, trailer-connecter harness, license plate, backup camera, etc.... Then time to clean her up and paint!
   / Building a flatbed for my F350 #69
Very nice work!!! Professional grade!!!
I tried the horizontal gas filler method. Puked fuel out unless filling slowly. Even then dribbled every time. Finally moved to a vertical position. Hope yours works okay. :)
Yeah I'm hoping so, but i expect it will be ok. It's now the exact same height as the factory mounting location was.
Meyer 8' Snow Plow w/ Bracket (A55272)
Meyer 8' Snow Plow...
2016 Toro Sand Pro 5040 Bunker Rake (A59228)
2016 Toro Sand Pro...
2013 COACHMEN CATALINA TRAVEL TRAILER (A55745)
2013 COACHMEN...
20FT X 12FT LIVESTOCK METAL SHED (A58214)
20FT X 12FT...
iDrive TDS-2010H...
2012 Ford E-250 Cargo Van (A59230)
2012 Ford E-250...
