Brush Hog Positioning
/ Brush Hog Positioning #22
SLOBuds said:
Here in California we are getting close to spring so I attached my new(used) brush hog to make sure it works OK and to do a bit of practice. Quite an effort to attach that thing! But I guess you all are used to the process of muscling 900 pound implements onto 6000 pound tractors.
Buy Pat's Easy Change.
https://www.imcuniverse.com/store/easychange.htm
/ Brush Hog Positioning #23
3RRL said:
However, here's my take on that. If you have rough land and are mowing over swales like where the tractor was pointing down one side and the brush hog going up the other side, I'll bet you would still scalp the top of the swale somewhat. Maybe not so much a gentle swale, but sharper ones for sure. Not only that, but as the cutter passes over the top, the center of it gets closer to the ground. The only way to keep the cut constant height is to move the cutter up, using the front or rear or both...or get rid of the swales of course.
Yes, I would have to agree that if you have extremely rough land, where you would constantly be having to change the position, the setup might not provide the results you require. However, the pic I included was of my RFM and the area I mow with it. My brush hog otherwise sees some pretty rough terrain and I have the same setup, except without the turnbuckles and a little heavier chain. Adjustment is made simply by moving the attaching point by one or more chain links. For the most part, I drop it down and leave it alone. Ocassionally, if I see a stump, large rock, etc. I raise the 3pt, but not otherwise. I think if I had even rougher ground (and in which case I'd require an even less finished look) I'd probably take another link out of the chain and just mow a little higher so swales, etc. were not a problem. It is a pretty cheap setup, easy to install, and probably worth a try for almost everyone at least once. Note that to work, it does require some sort of moving top link, toggle or piece of chain for the top.
/ Brush Hog Positioning #24
gerard said:
Gerard's technique sounds like it might work well for me. The cutter looks like it will float by attaching chains in that manner. Gerard - if I picture this accurately, you raise the lower arms only for installation of the chains. Then when you are cutting the arms are probably lowered all the way down which makes the cutter held up to the elevation set by the chains. Correct?
Correct - What it does is let the chains hold all the weight of the front of the deck and keep the front skids off the ground. I'll have to work on a picture - my bushog is out under snow but google check chains and you should be able to see a picture.
/ Brush Hog Positioning #25
SLOBuds said:
I also like the idea that you can use the check chains to quickly set the cutter back down to the elevation you intend - my 3pt height mechanism is kind of sticky for some reason that I'm not sure of yet.
djradz, your check chain assembly actually does not look bulky enough for my tractor/terrain/cutter weight. But it is a good setup that would not be difficult to fabricate. Easy to see how I would simply use a larger chain and beefier attachment hardware. I pictured this not set onto the base of the cutter though, but up on the 3ph pin attachment, on the cutter.
You're correct - mine attach to the pins on the cutter, not the cutter itself but it would work the same way and yes - use the heaviest chain you can - mine looks like the same size as the picture and I've snapped links twice and had to reweld them. Hit a bump and that's a LOT of instant tension on the links.
/ Brush Hog Positioning #26
mjfox6 said:
Not an ad but I bought a set of these and sold my quick hitch. Well worth the money and work as advertised. This style is what you see on the bigger tractors as stock because those implements are too big to muscle around. These things work great, back up, line up and lift arms, locks in automatically and all you have to hook up is the toplink. I'd never be without a pair again
/ Brush Hog Positioning #27
I also recommend them.
My cat II stuff is heavy to muscle around and Pat's EZ change made a great difference in ease of attaching. I met Pat lat month at the Tulare Ag Show in CA. Bought another set for my wife's tractor from him there. He's a real nice man and has a great product.
2012 Mazda 3 Sedan (A61574)
2012 Mazda 3 Sedan...
2017 Ford F-250 4x4 Crew Cab Pickup Truck (A61573)
2017 Ford F-250...
PALLET OF SCRAP AND TIRE (A63291)
PALLET OF SCRAP...
Caterpillar T Series Lift Truck Service Manual (A63117)
Caterpillar T...
Champion Vibratory Roller (A60462)
Champion Vibratory...
2016 Chevrolet Silverado 1500 Pickup Truck (A61573)
2016 Chevrolet...
