Brush Hog Positioning
   / Brush Hog Positioning #11
I've found it makes a brush hog easier to hook up if you set the skids on 4x4's. Mine is stored outside on grass. You can slide it back and forth to postion it with a piece of pipe about 4' long. It makes it lot easier to work with and is easier than it sounds and is sure easier than having it sitting on the ground.
   / Brush Hog Positioning #12
SLOBuds said:
Thanks all.
My property now has hills, bumps, ground squirrel holes and many other features. The first (unexperienced/'practice') runs ended up scalping and gouging the dirt quite a bit. The tractor pushes the cutter down every time the tractor nose is pointed up.
Gerard's technique sounds like it might work well for me. The cutter looks like it will float by attaching chains in that manner. Gerard - if I picture this accurately, you raise the lower arms only for installation of the chains. Then when you are cutting the arms are probably lowered all the way down which makes the cutter held up to the elevation set by the chains. Correct?
You may not avoid all scalping that way, but the tractor itself will not be pushing the cutter down into the ground as much. Correct?
Would there be any benefit in attaching the toplink with a chain also to increase and improve the floating even more?
Lots of guys use chain on the top link exactly for that. There's been a lot of discussion about having too much play though ... something about the cutter being able to flip up towards the tractor if it hit something really bad. Although I've never seen or heard of it actually happening, the top link is supposed to stop the flip if that were to happen. There are semi-rigid hinged top link sway bars that allow some float, but are still rigid after that. Mine has a 4" long slot for the top link pin to float in the cutter top connection for that reason. Sometimes I need more float than that, but normally it's adequate.
Even with the check chains if your ground is like you say (much like mine) you'll want to pull up the 3p arms when approaching a dip or mound just to decrease the amount you scalp or cut dirt. I used to set the tailwheel pretty high just so I could do that. I'd lower the front more than the inch or two just so that I could lift it up when I needed.
There were times I wanted to increase the height of my tailwheel on the fly too, so I made a custom set of hydraulic tail wheels for my cutter. Your can see what I did in this thread Quick Attach Hydraulic Gauge Wheels and the one before that. It works on land like mine, and apparently, it would on yours too. Now I can raise the front AND rear when I want, without having to "carry" the mower on the 3pt alone. I think I can get about 14" up on the tailwheel now.
   / Brush Hog Positioning #13
Check chains are the ultimate way to provide consistant trailing at a constant level. As set up, the top link floats and the front of the deck rides with the rear wheels of the tractor - much steadier than any little 10-12 inch wheels. The pic attached is of a rear deck, but a brush hog would be set up exactly the same as far as the chains are concerned.
   / Brush Hog Positioning #14
My "Bushhog" is the same, one rear wheel on a caster. This is not adjustable. So the only way for me to adjust cutting height is to play with the combo of 3pt and top link. My "A" frame has a chain that runs back to middle to keep the deck from tipping backward.
Wedge
   / Brush Hog Positioning #15
I can see they would provide less up and down movement than the lower drag links since the connection to the tractor is closer/ahead of rear the wheels vs the being far out back like the drag link connection is. Especially if your land is nice and flat as shown in the background.
However, here's my take on that. If you have rough land and are mowing over swales like where the tractor was pointing down one side and the brush hog going up the other side, I'll bet you would still scalp the top of the swale somewhat. Maybe not so much a gentle swale, but sharper ones for sure. Not only that, but as the cutter passes over the top, the center of it gets closer to the ground. The only way to keep the cut constant height is to move the cutter up, using the front or rear or both...or get rid of the swales of course.
   / Brush Hog Positioning #16
To me the biggest advantage to using check chains is that without Position Control it allows you to set the cutting height you want..... and then be able to raise the cutter as needed to clear obstacles......and then lower it back quickly to your mowing height without having to fiddle around.
   / Brush Hog Positioning #17
That's the way I see it, too. That's also the advantage of my EH 3pt. I can set my low (down) position and my high (up) position and the rate at which it moves from one to the other. Then, I push the up or down button and it will automatically rise or fall to the point I have set at the rate I selected This works great for evenly emptying a box blade, etc. and also for bushhogging. Of course my position slider overrides the settings and I can use it at any time (such as when I am nose down and need to override the low point).
I think that operating a 3pt implement on any kind of terrain will require you to finesse the 3pt. It's a skill you have to take the time to learn. In my experience, 3pt. work is seldom, if ever, a "set it and forget it" operation...
I also like the idea that you can use the check chains to quickly set the cutter back down to the elevation you intend - my 3pt height mechanism is kind of sticky for some reason that I'm not sure of yet.
djradz, your check chain assembly actually does not look bulky enough for my tractor/terrain/cutter weight. But it is a good setup that would not be difficult to fabricate. Easy to see how I would simply use a larger chain and beefier attachment hardware. I pictured this not set onto the base of the cutter though, but up on the 3ph pin attachment, on the cutter.
3rrl, It is hard to imagine a cutter my size actually flipping UP. It would have to be some pretty mean forces to do that. I have a clutch that absorbs all of my unintended hits. And I cut with my fel low to the ground - kind of a hassle when going over all of those dips on my land. But especially when I am starting out here, I will keep it low and maybe avoid some large obstacles. Plus my land is hilly and I do not yet feel comfortable operating at an angle. I know that first thing to do during a threatened tractor tipping is to put fel to ground.
And just to close this out I should say that my plans are to eventually get the parcel smoothed out through discing and leveling. A longer term project however.
Meanwhile, check chains look great! I'll give some thought about chaining the toplink also and let everyone know how it turns out.
Thanks again,
Martin
And I will try some of the positioning suggestions also!
   / Brush Hog Positioning #19
Hmmmm, I don't mean to sound mean but, you haven't run a cutter long have you?
The clutch you are talking about is the slip clutch on the PTO shaft, right? That does absorb the shock load of hitting an object - but only in the drive line. It protects the PTO assembly in the tractor. The laws of physics are still operable and that huge spinning mass in motion, when stopped by hitting a steel pole sticking 8" out of the ground, will translate into other energy. The slip clutch does not make it go away. Maybe it will translate into the activation energy needed to shatter steel, probably not. Maybe it will translate from rotational engergy into linear energy and shoot down into the ground - probably not. Maybe, just maybe it will take the path of least resistance and shoot up and flop onto you. Hmmm - sure would be nice to have a solid linkage between the tractor and the cutter -WHEN, not if, WHEN- that happens.
Your comment on it "being hard to imagine that happening" is pretty much what everyone says - after it happens.
jb
   / Brush Hog Positioning #20
Good for you Martin,
Looks like you'll do fine with what you're planning.
I certainly agree with what has been said, using the check chains to get back consistently to the same height/position. It's an easy, reliable and proven method. No doubt about that and I was not disagreeing with that at all. More so, what bjcsc said, working the 3pt is not always a set it and forget deal ... I guess that was my point too and he just said it a lot better than I did.
As far as the cutter flipping up, you're right, it's very unlikely. I said above that I was only bringing up what was discussed in past threads and that was one of the concerns mentioned in one of them. I have never seen nor had it happen to me, but I have had the cutter "jump" up several feet after running over something big even with the fel low, so I'm thinking it's not impossible.
2017 Ford Explorer SUV (A56859)
2017 Ford Explorer...
2007 8'x20' 2 Axle Sprayer Trailer (A57148)
2007 8'x20' 2 Axle...
2019 Takeuchi TS80V-2 Rubber Tire Skid Steer, PIN# TKV80201102, Deutz Diesel Engine, Joystick (A59076)
2019 Takeuchi...
New/Unused Electric Golf Cart (A57453)
New/Unused...
2012 BIG TEX PIPE TRAILER (A58214)
2012 BIG TEX PIPE...
12V 20GPM Gasoline Fuel Transfer Pump (New/Unused) (A59225)
12V 20GPM Gasoline...
