Rotary Cutter Brush cutting for beginners...
/ Brush cutting for beginners... #31
What you are describing is perfect for a rotary cutter. I am not sure what the growing conditions are in NE TX, however mowing the right of way a couple times a year would most likely be adequate. With my experience a flail with side slicer knives does not cut the woody stuff the best, it has a tendency to defoliate it but not cut it. A rotary cutter is made just for what you are looking for. The first time will suck as there are things you wont be able to cut and will have to root them out, or cut flush with ground. You will also find rocks, and other surprises. A rotary cutter can chuck a rock, however most will have guards on them to prevent it from flying high. The professionals use rotary cutters when doing right of way clearing for a reason, they are the best tool. The results will look good, but not a lawn. Decide what size tractor you want, and then size the rotary cutter to it. Also get a slip clutch its worth it!
Thanks. Slip clutch and chain guards are on my must- have list thanks to everyone's advice.
Is the dual wheel worthwhile if I am just looking for a rough cut?
/ Brush cutting for beginners... #33
As you, hopefully, figured, it's a good idea to walk the entire area before throwing swirling metal at it. RCs' stump-jumpers mitigate impacts to large objects, but snagging a bunch of fencing will bring out voices in your head stating "I told you to walk the area!"
I'm guilty of brush cutting blind. Walking in huge patches of blackberries isn't fun. I didn't know an area that I was cutting in was an overflow wrecking yard area... (sliced through metal car rims and other stuff; my lowly light-duty RC and B7800 survived it all!)
IF you were to hire out the first mowing/clearing or two you'd mitigate the danger of hidden debris. Once someone else clears you can more readily see what's there.
/ Brush cutting for beginners... #34
Dual wheels have a tendency to fight each other when backing up. However they do reduce scalping so its a toss up. If they are more money then I would not get them, however that is my personal opinion and experience.
2014 FREIGHTLINER CASCADIA (A60736)
2014 FREIGHTLINER...
2014 International DuraStar 4400 Service Truck with Crane, VIN # 3HAMKAAN0EL771639 (A61165)
2014 International...
2019 International WorkStar 7300 4x4 Altec AA55 56ft. Insulated Bucket Truck (A60460)
2019 International...
17102 (A56859)
17102 (A56859)
Utility Cart (A59231)
Giyi 2WD Mini QA Excavator Arm (A60463)
Giyi 2WD Mini QA...
