3-Point Hitch Broken three point hitch
/ Broken three point hitch #1
haystack
long valley, nj
Ford 7600
:confused2:I just got a 284 IH and lifted the draw bar up and know it is stuck and will not lower . Can anyone tell me how to fix this I never had anything like this happen to any of my other tractors.
/ Broken three point hitch #2
I'd assume you mean you lifted the three point. Your tractor should have a knob that turns to adjust the rate at which your three point lowers. If it is turned all the way it will not lower without enough weight on it.
I tried that but it didn't work it almost seems like a metal rod is stopping it . I was told the unit might be off center and I know have to lift the hole seat cover off and I will see the problem
/ Broken three point hitch #4
Does it have a draft control? If so, make sure the draft lever is in the down position.
2021 Kubota SVL75-2 Track Loader (A63689)
2021 Kubota...
Big John Semi Trailer (A65640)
Big John Semi...
JCT 72" BRUSH CUTTER (A67148)
JCT 72" BRUSH...
2016 Komatsu WA320-8 Articulated Wheel Loader (A64553)
2016 Komatsu...
2016 INTERNATIONAL PROSTAR+122 6X4 ROAD TRACTOR (A65054)
2016 INTERNATIONAL...
1990 FRUEHAUF 53' DRY VAN TRAILER (A65054)
1990 FRUEHAUF 53'...
