3-Point Hitch Broken three point hitch
/ Broken three point hitch #1
haystack
long valley, nj
Ford 7600
:confused2:I just got a 284 IH and lifted the draw bar up and know it is stuck and will not lower . Can anyone tell me how to fix this I never had anything like this happen to any of my other tractors.
/ Broken three point hitch #2
I'd assume you mean you lifted the three point. Your tractor should have a knob that turns to adjust the rate at which your three point lowers. If it is turned all the way it will not lower without enough weight on it.
I tried that but it didn't work it almost seems like a metal rod is stopping it . I was told the unit might be off center and I know have to lift the hole seat cover off and I will see the problem
/ Broken three point hitch #4
Does it have a draft control? If so, make sure the draft lever is in the down position.
2011 International DuraStar 4400 18ft. Cab and Chassis Truck (A64194)
2011 International...
TROY-BILT GENERATOR (A64553)
TROY-BILT...
2025 GIYI GY-P45 Hydraulic Breaker Mini Skid Steer Attachment (A64553)
2025 GIYI GY-P45...
121A (A63745)
121A (A63745)
STIHL HT250 POLE SAW (A64276)
STIHL HT250 POLE...
Gannon 12in. Bucket with Teeth Excavator Attachment (A64194)
Gannon 12in...
