Broken Mount For LA724
/ Broken Mount For LA724
Strange ... looking at the OP's original photos ... and then at my FEL, which was bought in July 2007, there appears to be a difference. My cast uprights have a heavy (sheet steel?) "flitch" plate, 3/16 or 1/4 inch thick; filet welded to the web of the casting. This reinforcement runs almost the full width of the upright and extends almost a foot vertically. I don't see any evidence of it on the OP's, or maybe I just can't see it?:
I may have to eat crow about Kubota wringing out weight without going overboard ...
Kcender, does your FEL have these plates, and is it newer than mine, or older?
-Jim
My tractor was purchased in July of 2010 and does NOT have these plates.This is new knowledge to me and very interesting.It seems like maybe Kubota cut some corners here to save some money on manufacturing costs.Who is to say if this would have prevented my problem but I would certainly think it would have made the bracket stand up better.I will mention this to the dealer when he looks at it.If Kubota doesn't do anything for me,and I won't be surprised,this is what I had planned on doing when I weld
the brackets.The only difference is that I was thinking of putting the plates on the inside but I don't see much difference one way or the other.Thanks for the photos and this helps to reinforce that the casting is weldable and probably cast steel judging from the amount of welding done to it.Cast iron usually doesn't accept this amount of weld without a lot of care that I don't think Kubota would be willing to do that.
/ Broken Mount For LA724 #42
Bummer :(
Just curious - what does your owners manual have to say about performing these type of manuvers ?
On a heavy-duty industrial backhoe maybe .....
Correct.
It's not so much that they are only made to do light work as much as it a case that they are not made to be completely abused ....
Just like any machine, they have their place, and they have their limits .... exceed the limits and you will likely have a problem at some point.
Personally, if I were you, I'd consider myself lucky - the loader mounts can probably be repaired fairly easily.
Imagine if you broken the ___________ (fill in the blank: rear end/differential, transmission, etc. ....)
I wouldn't call that abuse. For the amount of money we spend on these units, we shouldn't have to treat them like on of my boy's Ertl toys. Abuse to me would be trying to move a brick house with the bucket, not having it support the tractor with no impact.
E
Baby Grand,just want to make sure if you bought the tractor new and that the extra plates were part of the manufacturing process from Kubota or is it possible that it was done later.
/ Broken Mount For LA724 #44
E
I hear what your saying, but nothing is indestructible, and these are not full framed permenant loader tractors. They are added to an ag tractor for moving material and light/medium digging. The hoe puts extreme stress over what is normal to boot. Its hard to guess without watching every hour of the ops use. Im not backing kubota by any means, believe me... I have the exact same 2010 loader mounts he does and its bothering the heck out me now that I see they deleted that gusset plate which was there for a reason. Ive watched my mounts flex also. Has me bit concerned and im curious what kubota says.
/ Broken Mount For LA724 #45
Apparently you missed it where the OP said:
"After looking at the other bracket I noticed that it has a crack in it as well ....."
See pic no. 5 in the OP :D
It's not the crack you can see but the ones you can't that will cause the plates to fail, hence the NDT.
/ Broken Mount For LA724 #46
It looks like a different casting altogether, I don't remember your's having as many "pockets" on the back side, and it definitely doesn't have the reinforcing plates welded to the outside.
Ritschner mentioned earlier that he thought they had changed the brackets recently. Maybe they tried a new design that wasn't supposed to need the plates welded to it, with a lack of success in this case anyway.
It might be stronger with the plates on the inside. From what I saw of yours today, it looks like they both cracked on the thinnest part of the web on the inside of the casting first, then spread to the outside. If you stiffen the inside, the web might not crack as easily, I think the steel will flex more if it's on the outside.
It'll be interesting to see what the guys from Nova have to say about it. May be worth talking with the regional rep from Kubota directly if the dealer can't do anything for you. Where they both cracked in exactly the same spot makes me think there's a problem with the design to begin with.
Sean
Sean,your eyes are sharper than mine.I just had a look at my brackets and they do appear to have a different web pattern than the ones on Baby Grand's.Mine must be the new and improved version:laughing:I will definitely mention this to Terry when he comes to look at the tractor.I think you are also right about putting the plate on the inside which is what I was thinking.I was thinking of both sides but I have to consider the inherent stresses from welding,more is not always better unless I had a way to stress relieve the part after welding. This would require a sizable furnace which I do not have.
/ Broken Mount For LA724 #48
Don't get me wrong, but there's many things I see mentioned here that some call "abuse" and I say "I won't be buying their product." What do they think we are going to use these things for? Expensive lawn ornaments? The whole "not made for pushing" line I see time and time again drives me nuts. Yeah, expect damage if you're pushing in mid range and strike a tectonic plate, but to spend the money for a 4000lb tractor with bucket and be told it is for nothing other than shoving around styrofoam is BS in my book.
I use my tractor for everything under the sun. I can't afford to go out and buy another complete piece of equipment, like a dozer, a skidder, and excavator, and so on for every job I expect my piece of equipment to do. My Boomer has done all of the above. No, it's not wanton crazy abuse of the tractor, I do everything I can to prevent heavy jots and bumps, whether it be mowing, box dragging, or transiting loam from the 60 year old pile down in the woods up to my lawn in progress.
Abuse, and expecting a failure, would be backing into a guardrail post at a low (not slow) speed with a rear mount finish mower. Yes, there was a failure, but no where near what I expected for the amount of force dissipated. ( the shop press and a set of falls got a workout on this one).
Breaking a FEL stanchion or even worse, breaking a tractor in half and being told "you shouldn't have put weight to it" is simply inexcusable and should put a mfg'er in a shameful position with it's sales base.
That said, yes, be thankful the failure was what it was. A few hours with plasma cutter and welder would make for a quick (and, obviously, better than new) fix if the manufacturer doesn't stand behind its deficient product. And, if you are already seeing the mounts flex, I'd be fabbing some backing plates and whatever gusseting is needed. That metal will only bend so many times before there is a fatigue related failure.
I think I need to grab my Dos Equis and head back downstairs to the Garagemajal.
/ Broken Mount For LA724 #49
Doesn't matter .... since it is not relevant.
That's certainly true ......... however ..... one should treat them like what they are (CUT's with an add-on backhoe) ..... not like what they are not (industrial TLB's)
It really matters very little what you - or I, for that matter - consider abuse to be.
What is relevant is what who designed, manufactured, and sold/marketed the machine considers abuse to be ....
If I had to hazard a guess, I'd say that the machines are designed with very specific intended use .... in my book, using them in a manner other than what they were designed for constitutes abuse ....
Do I do that ? ...... of course .... :D
But I ain't gonna blame the manufacturer if there's a problem when I do .....
Just because you (or I .... or anyone else for that matter) "feels" things "ought to be a certain way" does not mean that they are.
I don't own the OP's particular model of CUT, loader, or backhoe - however, I do know what Kubota says in the manual for my backhoe (BH4690B - which fits both "B" and "L" series Kubotas):
"Due to the configuration of the tractor, with separate operator's stations divided by the ROPS, the backhoe should not be used to move the unit. The boom and dipper and both stabilizers should be raised to clear ground level, and the unit should be moved along the trench line or excavation with the tractor."
Seems fairly straightforward to me ....
Additionally, it says the following, with regard to using the backhoe to backfill an excavation:
"DO NOT use the side of the bucket and lateral swing to attempt to backfill. This method places huge stresses on the entire backhoe frame that will cause major failures that can effect the entire tractor-loader-backhoe." [Emphasis mine]
And finally:
IMPORTANT:
Lateral swing backfilling is perhaps the most common abuse placed on backhoes today. All backhoes are designed as digging units. They are not to be used as prying units.
Personally, I think it really isn't all that difficult for a fairly intelligent person to draw some reasonable conclusions from the above cautions.
Terry from the dealership where I bought my tractor was just down to see the bracket.He said he found it hard to believe that the bracket broke.I showed him the crack in the other bracket and he agreed the cracks were in exactly the same place on both brackets.He took pictures and said he would contact Kubota the first of the week.I told him I didn't expect much from them but he said you never know how they are going to respond.I mentioned to him about the brackets on Baby Grand's tractor with the reinforcing plates and he asked me to send the photos to him,which I did.So now I wait.
/ Broken Mount For LA724 #51
Well lets hope Kubota steps up and replaces them. Maybe even decides to upgrade them to something stronger. It's possible that when they designed the brackets they never thought about a backhoe, just the forces involved with the fel.
Crazyal,I am curious about the brackets on your L4240.I realize you have the heavier loader,LA854 I believe,but it is physically very similar to the LA724.Does it have the same setup as my loader brackets and if so does it have any reinforcing plates.What year is your tractor?Thanks.
Just a thought on this broken bracket.I don't think this failure is due to one incident but rather is the cumlative effect of many hours use.The rust on the broken bracket shows it was cracked long before the total failure.I would also bet that the crack on the other bracket has been there awhile.Because the cracks are in identical spots on each side I am leaning toward a poorly designed bracket.The removal of the reinforcing plate leads me to believe that the brackets are not made as strongly as they once were.My tractor is only 15 months old but I have put 531 hours on it which is probably heavier use than most utility tractors get.Some people might take 10 years to put this many hours on their tractor.My point is that more of these failures may start to show up as tractors get older with more hours use but lets hope not.The failure could be because of how I used the tractor but I really don't feel I abuse my tractor to the point that something like this would happen.:2cents:
/ Broken Mount For LA724 #54
And finally:
IMPORTANT:
Well, gee whiz professah, thanks for calling me an idiot. Also, thank you also for pointing out that Kubotas make a better lawn ornament than a usable tool. I knew there was a reason I didn't even consider orange when I was on the market.
/ Broken Mount For LA724 #55
So far you're the first I've heard of, sorry but because I have the 854 I hope it's just you, nothing personal. :laughing:
Hey Crazyal,I hope this is an isolated incident as well,especially if I manage to get the brackets replaced with the same type.I am still curious about the design of your loader brackets but you didn't mention anything about them:(
/ Broken Mount For LA724 #57
Wow really? It has nothing to do with color, its called using a machine within its capabilities. Using your logic, a 1/4 ton datsun pickup should be able to carry 2 tons of brick because it would fit in the bed. And I guess deere makes good lawn ornaments too, heres a quote from thier cut backhoe manual
IMPORTANT: Avoid damage! To help prevent damage to backhoe:
Raise tractor only with stabilizers.
/ Broken Mount For LA724 #58
They look like yours. Solid on the outside with a pattern cast into them on the inside. No plates welded on.
/ Broken Mount For LA724 #59
Actually ....... I didn't call you an idiot .... not even close .......
Rest assured, there would be absolutely no doubt in anyone's mind if I had ....
I merely gave my take on what a reasonably intelligent person would do when given the benefit of being educated and cautioned by the maker of perhaps a very expensive piece of equipment that they own.
Apparently you seem to be suffering from ... a sense of entitlement .... due to dollars spent ....
Believe me - I understand .... BT ..... DT ...
My take on it is, you are certainly entitled to do whatever you wish with your own personal property.
However, if you - or anyone else - deliberately and purposefully choose to ignore the manufacturer's recommendations and cautions with regard to proper operation of a product they produced, then ...... it's on you, or anyone so choosing, as to what happens .....
No whinin' allowed .... :D
Oh well, yeah ..... now I'm really highly offended ..... deeply, I tell ya :rolleyes: ..... you have gone and said something derogatory about the brand of equipment I own ..... :rolleyes:
What's next - you gonna tell me my mother wore Army boots ? :D
Wanna know what kind vehicle I drive, so you can rag on that too ?
FWIW, I happen to think Kubota - for the most part - makes a pretty decent product. Occasionally they, like any company, screw up and make bad choices .... personally, I think the subject of this thread might be one of those times.
As I stated, I have and do occasionally "work" my equipment pretty hard ..... in some instances, contrary to the manufacturer's recommendations.
As an example of that, here's a couple of pics of our old driveway that I removed (roughly 600' long):
Much of that removal was done entirely with my loader (probably better than 50%, maybe as much as 75% ....) ..... stick the bucket edge under the asphalt and curl ..... and when I couldn't get any purchase on the asphalt's edge, I'd back up 3' to 6' or so and stomp on the HST pedal (mostly in Low range .... but sometimes in Medium ... and more than once in High ...)
It was an absolutely stupid thing to do .... but I didn't know any better at the time. It was abuse .... whether I believed it was or not.
FWIW, the second picture is a little deceiving .... since it looks like the pavement is pretty much entirely crumbled ..... it wasn't. There is two layers of asphalt and it ranged from 4" to over 8" thick in spots (5" to 6" average) ...
Some of it was so solid that I couldn't peel it up with my little backhoe ...... or with a 8000 lb. Kubota KX91-3 mini-ex ....
Despite my foolishness, I didn't break or damage anything on my tractor or loader .... at 1200 hours on the clock (which is about 800 to 900 hours later), my loader and bucket is straight and not tweaked.
If I'd had a problem though, it would have been on me .... because I'm fairly sure that what I decided to do with my equipment wasn't what the manufacturer had in mind.
My apologies to the OP for the hijack ... :confused2:
/ Broken Mount For LA724 #60
Yes, bought the tractor (with loader), new, in Summer of 2007. Other than adding hooks to the bucket, I have made no alterations to the loader. Good luck with Kubota, I hope they man-up on this one.
-Jim
