Bringing Power In
/ Bringing Power In
Tim,
No, this pole isn't under any stress from wires pulling on it. It's 4 ft in the ground and the top of the uprisers have to be at least 12 ft above grade for the power company to connect the wires to.
Eddie
/ Bringing Power In
I dug my trench about half way, then unrolled my wire. It's 4/0 URD for direct burial. My trench is 8 feet deep at the panal and slowly works it's way to six feet and will end at four feet.
The reason I'm so deep is that in the future water and sewer lines will cross over these wires, and I don't want to risk digging them up again.
/ Bringing Power In
Here's the view from the bottom of the trench. I got lucky and was able to push the wire up through the 2 inch conduit into the disconnect box. It was one of those jobs that you measure in inches with lots of breaks!!!
/ Bringing Power In
Way back when, I used to seal off the pipes with plumbers putty. Not the best method that I've come across.
I like expanding foam!!!!
/ Bringing Power In #85
Eddie-
No criticism intended, but seeing that picture from the bottom of the trench without shoring makes me cringe. I'm not sure what type of soil you have there but anything deeper than waist deep is a potential hazzard without shoring.
That being said, it is a neat picture!
Bonehead
/ Bringing Power In #86
It's a fine line about being "preachy" but I agree about trenches. They look fine but if the dirt dries out, the weight of the damp stuff behinds it causes hundreds of pounds, even thoussands to fall off with the slightest provocation. I've read a dozen or so death reports on guys dying in trenches. Even with dozens of men trying to get them out immediately, the victims suffocate. No one can tell when or why they go and believe it, every single person that has ever been buried thinks the dirt is just fine. Our pool was dug out back. The darned stuff looked like concrete! During the middle of the night, we heard this deep "WHOMP". I went out back to investigate only to find out that a large section of the dig had caved in. Scared me to death!
About that direct burial. I apologize if you know already: Put it on sand and bury it with sand, then pea gravel, then waste ROLLS of red vinyl tape on top of that. Anytime a dig is in progress in the future, you'll pull that red tape up as a warning and it'll save the cable. The sand will keep sharp rocks from working their way through the insulation over time. No one can tell me it can't happen, I've seen it twice, once on cable, once on a pipe. That cable will have a subtle, seemingly harmless 60 cycle buzz to it, perfect for rubbing a hole. (same reason cables work out of their lugs)
/ Bringing Power In
Thanks for the concern about the trenches. It's one of those things that I'm aware of, know it's a bad idea, and do anyway. The worse part is it was 8pm with nobody around and not expecting anybody until the following morning. /forums/images/graemlins/confused.gif
I'm not saying I'm the sharpest tool in the shed, but sometimes doing dumb things is the quick solution, and I take the risk. Hopefully I won't find myself on my knees feeding cable up through conduit 8 ft down again.
On a brighter note, TXU was here bright and early connecting my wires. They had to struggle with the size of it, but after a few hours, they got it done.
I never expected two boom trucks and a supervisor in a third truck, but I appreciate the service.
/ Bringing Power In
This is the finished product. I angled the shot to maximize the wire and connections. From most angles and a little distance, it all disapears in the background.
The meter is scheduled to be installed today. You have no idea how tired of listening to my generator I am. /forums/images/graemlins/frown.gif
/ Bringing Power In
Here's a closer view of the connections. Not much to do about it.
/ Bringing Power In
Here's the inside of the disconnect box. The top two, right side breakers are the ones I've connected to power the workshop.
The rest will remain empty for now.
It's kind of expensive up front paying for all this when I only needed 200 amps, but down the road I'll see the benifits of doing it now.
/ Bringing Power In
Now that one end of the run is connected, I need to finish my trench and connect the other end.
It's not all pain and suffering. This part of the job I got some tractor seat time in and moved some dirt. /forums/images/graemlins/smile.gif
/ Bringing Power In
Back at the workshop, I stubed in two 2 inch conduits for this very day. I like to use five gallon buckets to mark my buried lines. They are easy to find and when you take them out, there's a good size hole already in the ground.
/ Bringing Power In
Once the bucket is out of the way and the trench dug, it's a simple matter of putting the wire through the conduit.
/ Bringing Power In
I connected the first panal and ran an outlet off of it for power. The only 20 amp outlet I had was a GFI, so that's what I used.
I figure that one outlet has cost me about $5,000. Of course, the second one I install with knock that price per outlet in half to only $2,500 each. /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif
This should be the end of this post. I now have power to my workshop and on the land.
Thanks for your comments and advice. They have been greatly appreciated. /forums/images/graemlins/smile.gif
Eddie Walker
/ Bringing Power In #95
Congrats Eddie, that's one huge step forward for your project! Maybe I missed it in the thread but where are the transformers? We have a transformer fairly close to the house as they told us there was too much distance from the house to the street for a pole mounted one. Just curious /forums/images/graemlins/smile.gif
/ Bringing Power In
Rob
The transformer is right next to the meter. Here's a picture that shows it, but you have to look close at the top of the pole.
Eddie
/ Bringing Power In #97
Aha! Mystery solved, thanks. And once again, fine job. Now you can plug your coffee maker in and really get going /forums/images/graemlins/smile.gif
/ Bringing Power In #98
What a great feeling that must be, to see such a massive project actually start to work!
Well done!
/ Bringing Power In #99
Ummm.......Eddie, you aren't going to put conduit on that wire going to the panel? /forums/images/graemlins/confused.gif
/ Bringing Power In
Inspector,
I'm putting up OSB on the inside walls that will enclose the wall cavity. My understanding is that this is allowed for a 200 amp main feed.
I've never seen conduit used in homes with sheetrock enclosing the cavity, so I assumed it would be alright.
Am I wrong?
For my overhead line going to my sub-panal, I'm using 2 inch conduit, but that's because it will be exposed in my rafters.
Thanks,
Eddie
2001 Peterbilt 379 Tri-Axle Dump Truck (A59230)
2001 Peterbilt 379...
2025 Kubota SVL75-3HFWCC High Flow Cab Track Loader - 70 hours
2025 Kubota...
2013 KENWORTH T800 DAYCAB BOBTAIL VAC TRUCK (A65643)
2013 KENWORTH T800...
1947 Chevrolet Panel (A62613)
1947 Chevrolet...
2020 Kinze 3505 High Speed 6/11 Planter (A63118)
2020 Kinze 3505...
72in. Fine Low Side Skeleton Skid Steer Bucket (A65640)
72in. Fine Low...
