jones6780
- Joined
- Nov 30, 2008
- Messages
- 423
- Location
- Lizella, Ga.
- Tractor
- Ford 1700 4wheel drive, Yazoo/Kees Max2 Zero Turn
So I am trying to get an old B&S engine running. Got it to run just a bit pouring gas down the carb. Took the carb off and soaked it in thinner, got everything cleaned up. The problem is that the threaded piece ( Has a 7/16 hex with external threads, screws into carb and internal threads, jet screws into) is corroded and broke. Now the engine shroud may have been changed as the Model 80312, Type 1524-01 shows a different carb on the parts list. My carb comes straight out from the horizontal shaft engine, has the tank mounted under with 1 pickup tube. There is no other numbers on the carb. The B&S parts website is down and I need help to find the part/prt# to get this running
