Branson tractor 2400 front end loader
   / Branson tractor 2400 front end loader #1
Omatchen
Gadsden,Al
2014 Branson 2400
The hydraulics quick connect 2 of the 4 won't connect on the front end loader . I't the red&white connection.
I can move the green & yellow to red & white it's snaps on fine. I can move red&white to the green & yellow it will
Not snap
New tractor I'm not that familiar with hydraulics
   / Branson tractor 2400 front end loader #2
Make sure the connections are clean. They should all be the same.
I had to clean the connections on my pressure washer to get them together. They had surface rust on them.
   / Branson tractor 2400 front end loader #3
might have pressure on them, loosen the fittings a see if they have pressure then try to connect
Thanks for your suggestion I located the problem
Thanks for input that was the problem
   / Branson tractor 2400 front end loader #6
On my Branson I have to shut off the engine and run the remote controls through a cycle to get easy engagement. Agree on pressure on one or both sides will inhibit connection.
Mark
2004 INTERNATIONAL 4300 BOX TRUCK (A51222)
2004 INTERNATIONAL...
2015 F-550 Bucket Truck Gas Engine (A52128)
2015 F-550 Bucket...
Ford F-450 Utility Truck (A52128)
Ford F-450 Utility...
CATERPILLAR 48" QUICK ATTACH FORKS (A51242)
CATERPILLAR 48"...
2015 Ford F-450 Crew Cab Knapheide Service Truck (A50323)
2015 Ford F-450...
2012 FORD F-550 SUPER DUTY XLT SERVICE TRUCK (A51406)
2012 FORD F-550...
