Branson tractor 2400 front end loader
   / Branson tractor 2400 front end loader #1
Omatchen
Gadsden,Al
2014 Branson 2400
The hydraulics quick connect 2 of the 4 won't connect on the front end loader . I't the red&white connection.
I can move the green & yellow to red & white it's snaps on fine. I can move red&white to the green & yellow it will
Not snap
New tractor I'm not that familiar with hydraulics
   / Branson tractor 2400 front end loader #2
Make sure the connections are clean. They should all be the same.
I had to clean the connections on my pressure washer to get them together. They had surface rust on them.
   / Branson tractor 2400 front end loader #3
might have pressure on them, loosen the fittings a see if they have pressure then try to connect
Thanks for your suggestion I located the problem
Thanks for input that was the problem
   / Branson tractor 2400 front end loader #6
On my Branson I have to shut off the engine and run the remote controls through a cycle to get easy engagement. Agree on pressure on one or both sides will inhibit connection.
Mark
2002 FREIGHTLINER FL70 DUMP TRUCK (A51406)
2002 FREIGHTLINER...
2014 UTILITY 53X102 DRY VAN TRAILER (A51222)
2014 UTILITY...
Skid Steer Plate Attachment (A50322)
Skid Steer Plate...
2021 CATERPILLAR 416 BACKHOE (A50458)
2021 CATERPILLAR...
2011 Ford F-150 4x4 Crew Cab Pickup Truck (A50323)
2011 Ford F-150...
UNUSED CFG Industrial MY50R Mini Excavator (A47384)
UNUSED CFG...
