Branson tractor 2400 front end loader
   / Branson tractor 2400 front end loader #1
Omatchen
Gadsden,Al
2014 Branson 2400
The hydraulics quick connect 2 of the 4 won't connect on the front end loader . I't the red&white connection.
I can move the green & yellow to red & white it's snaps on fine. I can move red&white to the green & yellow it will
Not snap
New tractor I'm not that familiar with hydraulics
   / Branson tractor 2400 front end loader #2
Make sure the connections are clean. They should all be the same.
I had to clean the connections on my pressure washer to get them together. They had surface rust on them.
   / Branson tractor 2400 front end loader #3
might have pressure on them, loosen the fittings a see if they have pressure then try to connect
Thanks for your suggestion I located the problem
Thanks for input that was the problem
   / Branson tractor 2400 front end loader #6
On my Branson I have to shut off the engine and run the remote controls through a cycle to get easy engagement. Agree on pressure on one or both sides will inhibit connection.
Mark
2018 Bobcat T595 (A47384)
2018 Bobcat T595...
2008 INTERNATIONAL DURASTAR 4300M7 SBA 4X2 DUMP TR (A51243)
2008 INTERNATIONAL...
1999 MACK CH613 WATER TRUCK (A50854)
1999 MACK CH613...
2015 Chevrolet Tahoe SUV (A50324)
2015 Chevrolet...
2013 CATERPILLAR 320EL EXCAVATOR (A51242)
2013 CATERPILLAR...
2016 CIMC 40FT CONTAINER CHASSIS (A52141)
2016 CIMC 40FT...
