Brainstorm with me!!
/ Brainstorm with me!! #1
HawkinsHollow
SE TN
Branson 3015R
I would like to make something to attach to my bucket to help me breakup and level some areas at my property. I have been doing a bunch of fill work and have gotten these areas close to how I want them but there are some inevitable dips and rises that I would like to level out. These areas have been driven on a lot and rained on some, so a regular old bucket back drag no longer does the trick. I was thinking ideally I could make something to attach to the bottom of my bucket so as I back drag it breaks up this surface, knocking down the high spots and filling in the low spots and finally smoothing it out a bit. I was thinking about having some chainlink fence trailing the bucket for the final smoothing. Has anyone seen a product like this? Does this make sense to do? Is there something cheapI could buy?
I was thinking something along these lines.
Have some teeth at the leading edge, a leveling bar then some chainlink pulled behind it for the final smoothing. Made into a nice implement I could chain under my bucket for areas that need smoothing.
/ Brainstorm with me!! #2
Land Leveler Saw this on Facebook Market place. Made to order.
I have seen those, that is what I am going for. Those are $800 to $2000, depending on the fanciness. I think I can make something similar for WAY cheaper
Have you considered an attachment for the rear. Like a box blade or a land plane?
I have a box blade but I am not impressed with the finish a box blade leaves. I am looking for something to do final leveling and smoothing. In my opinion a box blade gets you close but not to a finished product
/ Brainstorm with me!! #9
Are you going to be dealing with sod clumps or dirt clumps or both. Either way do you require some type of rolling clump buster vs just dragging and hope they break up vs leaving gouge marks?
/ Brainstorm with me!! #10
Is the dirt bare or growing things now. I have seen drags that are pulled behind small three wheeler on baseball fields
/ Brainstorm with me!! #11
I'm interested in this thread also. Would love to have something on the bucket to help out with the implements (landplane) on the rear. Especially for up around a house where it may be hard to get a land plane in tight spots.
Bare new dirt. For at least the next few weeks, I live in the south. It's like a jungle down here in the summer.
It is a little too hard already, needs something with a little down pressure I think.
/ Brainstorm with me!! #15
You could try a couple of passes. So, pull something behind to break it up a bit. Harrow? Then come back or a final pass with your back dragging, or land leveler.
/ Brainstorm with me!! #16
Saw a loader bucket at a farm show with scarfiers mounted on its back surface and pointed toward the tractor, for back dragging. With the bucket bottom flat on the ground, the scarfiers didn't touch the ground. With the bucket curled back, the scarfiers penetrated. If you floated the curled bucket, the bucket's chamfered facet worked the chunks thrown up by the scarfiers. Weight in the bucket might help.
/ Brainstorm with me!! #17
If it's hard, you may need a land plane and follow it with a drag harrow or any kind of drag. The land plane will get it really close but then I have a drag harrow to go behind for the final grade.
I just ordered this also. to follow the land plane.
/ Brainstorm with me!! #18
Find a good 10 ft of heavy chain link fence. Bolt together two 2x4 on one end with the fence sandwiched between. Put 3 or 4 cinder blocks on the front and drag with 4 wheeler. Turns out nice .
/ Brainstorm with me!! #19
Lots of good and cheap options. I use an upside down wooden pallet with a couple concrete blocks on it. Cuts the high spots and holds the dirt/gravel till it crosses a low spot.
Lots of good responses here. I think it needs to be relatively rigid and able to be placed under the bucket to allow the tractor to apply downward pressure. I am thinking a frame with a couple pieces of angle iron welded crossways, maybe one with teeth to cut and a third one to pull material with it to fill in low spots and then a trailing piece of chainlink to do the final leveling. I will see what I can fab up and report back.
2013 FREIGHTLINER CASCADIA SINGLE AXLE DAY CAB (A59904)
2013 FREIGHTLINER...
More info coming soon! (A56859)
More info coming...
2020 FRYFOGLE 40 LOG TRAILER (A59905)
2020 FRYFOGLE 40...
2021 Ver-Mac PCMS-3812 Solar S/A Towable Trailer Message Board (A55973)
2021 Ver-Mac...
2020 FORD F-150 XL EXTENDED CAB TRUCK (A59823)
2020 FORD F-150 XL...
1982 LeeBoy Motor Grader (A55302)
1982 LeeBoy Motor...
