boxblade v. rake?
/ boxblade v. rake? #1
VTtractorguy
Vermont
Still looking...
Sorry if this has been covered before, but here goes… We have a 2000 foot driveway which is hardpack. Pretty solid stuff. I want to buy either a boxblade or rake to maintain it. It is a gentle rise up to the house and about 12 feet wide. Over time I will have a truck load or two of hardpack dumped which I will spread and level. So what will work best for digging through the dense base and/or adding new material to level?
Thanks very much.
/ boxblade v. rake? #2
I would say the box blade would be better for the initial work of regrading the driveway,but the landscape rake will be better once that work is done.Your'e not going to loosen any hardpacked material with the rake. The advantage of the rake is you can touch up the drive when it needs it. It will also work for removing snow. Angle the rake and lower it just so it touches the stone. With the rake set like this you will not be plowing off the stone on your driveway. It will also loosen up alittle sone on the surface to give you better traction.
/ boxblade v. rake? #3
I agree 100%. I always used a boxblade, but just recently bought a landscape rake to clean up parts of my pasture. I have found all kinds of projects that the rake will work a lot better than my boxblade. You will probably need both.
D.
/ boxblade v. rake? #4
There is no question in your case a box blade. I love the landscape rakes for maintaining gravel driveways, but living in Vermont and dealing with sub-freezing temps in the winter daily, the LR will not do any digging but would skip above the surface. I borrowed a dealer's LR though and in warmer summer it did great (better than my BB) for smoothing the drive. It just does not have the versatility though to buy it INSTEAD of a BB; why choose though, get BOTH!!!!
John M
/ boxblade v. rake? #5
dirtworks got it right. I bought a BB when my drive (about 500ft) was a shambles, got it into shape toot sweet. Once that was done the rake is all I've needed to keep it in shape. A quick swipe every couple of months and it's as good as new.
The Frontier BB (at a steep $900) has been virtually unused on my drive since. Although I do a nice little side business with it in the spring cleaning up the neighbors driveways.
If all you're going to do is maintain your own driveway try to rent or borrow a BB and buy a rake - you'll be all set.
-Norm
/ boxblade v. rake? #6
D.
ddivinia, I'm curious how you are using this in your pasture. What exactly are you doing with it? I know it's commonly used on dirt drives but I have always wondered if it would help turn my former field into a better lawn.
/ boxblade v. rake? #7
I specifically use it to clean up "junk". I have been clearing cedar trees and burning them. So, I run that thru the ashes, etc to catch what I missed like rocks, old fence posts, barbed wire, etc. It does a great job of finding all that stuff.
D.
/ boxblade v. rake? #8
Neophyte,
I've "re-done" a couple of former farm fields that have been converted into house lots. I'm not an expert at it but the BB was used to knock down the old crop rows and with the scarifiers set deep I could pull up old roots, rocks, and the occasional tangle of barb wire or irrigation pipe. A couple of passes with the BB would get the field reasonably level and then several passes with the landscape rake would finish it. Oh, I should mention that gauge wheels on the landscape rake are essential.
A FEL is essential. The process created lots of scattered mounds of debris that had to be moved.
Good luck. -Norm
/ boxblade v. rake? #10
Were you running the LR over dirt or grass? My field is currently all grass/ weeds that grew wild, however, it is lumpy and very hard to walk on barefoot. Would an LR help me in this case or should I be using a drag harrow (harrow rake) or something else?
/ boxblade v. rake? #11
I think a landscape rake will work in your situation.
D.
/ boxblade v. rake? #12
I used the BB to break up the old field (knock-down high spots, fill in the low), the LR was used to apply the finishing touches. I ended-up with flat, barren soil that had to be seeded.
-Norm
/ boxblade v. rake?
Thanks all for your replies. Very helpful. I'll be buying a landscape rake first then maybe the BB. Any suggestions on the rake? York, Landpride, Frontier, etc? Or are they all about the same?
/ boxblade v. rake? #14
I have a 650' hard pack limestone drive and the rake is my implement of choice. It is quite steep and has a propensity to develope whoop de' doos every month or so. After a good rain I'll take the rake up there and smooth it out like new money. It's virtually impossible to get the whoops out when it's dry. If too wet you'll make a mess of things as well. After an all night rain the next afternoon is about perfect, compliant enough to move the material but not so muddy and sticky as to make a mess. If you try it a few times you'll figure it out quick enough. Make a wonderful job. Also, works great for snow removal as a fellow poster stated.
John
/ boxblade v. rake? #15
How do you use it to clear snow? Do you turn it around 180 degrees and drive backwards or do you just leave it forward facing and drive over the snow? Does anyone have any pictures of this?
2018 GENERAC MOBILE PRODUCTS MLT6S (A68842)
2018 GENERAC...
STIHL HT250 POLE SAW (A64276)
STIHL HT250 POLE...
2025 Swict 78in Tooth Bucket Skid Steer Attachment (A66734)
2025 Swict 78in...
2014 Chevrolet Impala Sedan (A66738)
2014 Chevrolet...
GENERAC MOBILE PRODUCTS  MAGNUM LIGHT/WATER PLANT (INOPERABLE) (A67714)
GENERAC MOBILE...
2001 FREIGHTLINER FLD132 XL CLASSIC (A67714)
2001 FREIGHTLINER...
