3-Point Hitch Box Scraper Won't Work
/ Box Scraper Won't Work #1
Don Hoffman
Massey-Ferguson 302 diesel
I call the photo below of my MF302 diesel "poor judgment." :laughing:
I am having trouble with my box scraper. It won't stay down while using the "rippers," with the Draft Control all the way down. Position Control is also down; Response Control is set to SLOW.
Is Draft Control only dependent upon the location of the "big nut" adjacent to the master control spring? How sensitive is this nut? Is there a range in which the system is in balance, or is there only one "sweet spot?"
The Service Manual talks about special tools including "wedges" to make adjustments to the 3-point hitch system. Is there an alternative procedure? I would appreciate any suggestions. :)
Thanks to the members who responded to my earlier posts about hydraulic fluid.
/ Box Scraper Won't Work #2
If you have the draft control down you need the position control all the way up. If you have the position control down the draft control lever should be pulled all the way up.
/ Box Scraper Won't Work #3
exactly...its sensing the ground as an obstruction, and is lifting to free the obstruction.
(INOP) 2013 MACK ELITE LEU633 GARBAGE TRUCK (A64280)
(INOP) 2013 MACK...
2015 Ram 1500 Pickup Truck (A64556)
2015 Ram 1500...
Toro ProLine 37in Walk Behind Commercial Mower (A64194)
Toro ProLine 37in...
12ft T/A Utility Trailer (A64557)
12ft T/A Utility...
Jack Daniels Sign (A64557)
Jack Daniels Sign...
2018 CATERPILLAR 573D FELLER BUNCHER (A64276)
2018 CATERPILLAR...
