3-Point Hitch Box Scraper Won't Work
/ Box Scraper Won't Work #1
Don Hoffman
Massey-Ferguson 302 diesel
I call the photo below of my MF302 diesel "poor judgment." :laughing:
I am having trouble with my box scraper. It won't stay down while using the "rippers," with the Draft Control all the way down. Position Control is also down; Response Control is set to SLOW.
Is Draft Control only dependent upon the location of the "big nut" adjacent to the master control spring? How sensitive is this nut? Is there a range in which the system is in balance, or is there only one "sweet spot?"
The Service Manual talks about special tools including "wedges" to make adjustments to the 3-point hitch system. Is there an alternative procedure? I would appreciate any suggestions. :)
Thanks to the members who responded to my earlier posts about hydraulic fluid.
/ Box Scraper Won't Work #2
If you have the draft control down you need the position control all the way up. If you have the position control down the draft control lever should be pulled all the way up.
/ Box Scraper Won't Work #3
exactly...its sensing the ground as an obstruction, and is lifting to free the obstruction.
New/Unused Quick Attach Backing/Mounting Plate (A65583)
New/Unused Quick...
Interstate 20ft Tilt-Deck T/A Flatbed Equipment Trailer (A64553)
Interstate 20ft...
2015 CASE CX160C EXCAVATOR (A65053)
2015 CASE CX160C...
2008 CATERPILLAR 242B2 SKID STEER (A65053)
2008 CATERPILLAR...
International 400 4R Planter (A66408)
International 400...
2023 KUBOTA KX040-4 EXCAVATOR (A65053)
2023 KUBOTA...
