Box blade for 20255r
/ Box blade for 20255r #1
tld
Boston, GA
JD 2025r
Need a box blade for new 2025r. Is the Frontier 2060 too much box blade for this tractor? BB info says its for 19-45hp. 2025 is 24 hp. but weighs 465 lbs. the 2025r is a little over 51 in wide so would the 2048 BB be better or not wide enough?
Thanks
/ Box blade for 20255r #2
Our ETA Xtreme Duty Compact Box Blades work great with tractors like yours.
I wouldn't go with a 48" because it wouldn't be as wide as your tractor.
The 54" or 60" would be my pick.
Shipping is free to a commercial business or to a freight terminal in Valdosta, GA.
Travis
Anyone else other than someone trying to sell something?
/ Box blade for 20255r #4
I have ordered everything attachment box blades and ordered a 96 inch one for my new tractor on friday. They make in my opinion the best stuff by far for the money. I had their 72 inch xtremem duty, graded land with stumps etc, snagged it on things, it didnt bat an eye. You won't be dissapointed with it. Comparing the frontier to the EA you will see lots of differences in favor the EA box blades. Better rippers, clevis hitch, rolled back, better cutting edges, more gussets, usually heavier with thicker plates. Laser cut so higher quality metal. I sold my old one with the tractor and the new owner is in love with it.
I wasn't asking for opinions on brands, but information on size for the 2025r. Thanks for the sales pitch though.
/ Box blade for 20255r #6
Sorry. I was giving you advice on the size for your tractor with our box blades as an example.
Would I like to sell one? Sure!
Would you be happy with one? Sure.
I'm not gonna come down there and twist your arm or anything!
Travis
Fair enough. Thanks.
/ Box blade for 20255r #8
The 48" is to small, you will want something a bit wider than your rear wheel base.
/ Box blade for 20255r #9
The Frontiers are plenty tough. I've had the 2065 on my 3320 for 6 years grading really rocky soil with boulders that will stop the tractor and its holding up great. Nothing has bent, both cutting edges are still fairly sharp and the paint is still in nice shape.
/ Box blade for 20255r #10
Get one just large enough to take out tire tracks.
Thanks to all
/ Box blade for 20255r #12
I have a 2025r and have not used a box blade but i have used a 5 ft rear blade and a 5 ft tiller and something to consider is you might need some front weight. the tiller i got will lift the front tires off the ground and if i get too aggressive with the rear blade it will do the same.
/ Box blade for 20255r #13
I have a 5 foot box blade from Tractor Supply and my Deere 2320 (same as your 2025R) pulls it just fine. With ALL the ripper shanks down, it sometimes bogs down a bit, but for 99.9% of what I use the blade for, a 5 foot one works perfectly. I have a 6' landscape rake and it works well, but it's a totally different implement with less HP requirements. I think 6' might be a bit too much for the 2025R in a box blade.
As far as the Tractor Supply "County Line" brand goes -- it's been a great tool, with no issues. Well constructed and sturdy despite a lot of abuse. For a 25HP tractor, it's constructed well enough that you won't destroy it. Just check the units at the store and buy one with good welds and no rust (since they usually are stored outside.) For half the $$ of what Deere wanted for a blade, I'm 100% satisfied with my TS CL brand blade.
JLG E300AJ (A60462)
JLG E300AJ (A60462)
211298 (A62131)
211298 (A62131)
New/Unused Wolverine 72in Quick Attach Ripper (A65583)
New/Unused...
2011 BRENNER TANK TRAILER (A65643)
2011 BRENNER TANK...
2016 VOLVO EC250EL EXCAVATOR (A62129)
2016 VOLVO EC250EL...
2012 Peterbilt 386 T/A Day Cab Truck Tractor (A60352)
2012 Peterbilt 386...
