Box Blade/Driveway Question
/ Box Blade/Driveway Question #1
koziol41
I want to make a gravel driveway off one end of my black top driveway.It would be a drive just to get to my pasture gate there is all grass there now would a box blade work on getting down deep enough to add gravel only have to go about 30' i really dont want to pay someone to do it.buying the gravel would be ok.Any comments or suggestions.have a JD 2520.
/ Box Blade/Driveway Question #2
Best way, is to remove the grass, then bring in about 3" of rock and spread it. If you dont remove the grass, it will come through the rock, it might anyway, if you dont put something to kill the grass.
Would the BB remove the grass?And would it remove maybe a couple inches of dirt so then i can spread the gravel?
/ Box Blade/Driveway Question #4
Yeah.. that's a box blade kinda job for a homeowner..
soundguy
/ Box Blade/Driveway Question #5
Yes, a perfect job you can yourself with your boxblade.
You might consider using the rippers down about 2 or 3 inches to cut the grass and break up the soil. Then scrape it off and smooth it. I would put some kind of pre-emergent down to keep the grass from coming back. Then use the boxblade to drag layers of gravel over it until you have the thickness you want.
You could even tilt your boxblade sideways using the side links and cut a small ditch next to the drive for water drainage.
/ Box Blade/Driveway Question #6
I agree with everybody else a BB will work just perfectly. Just remove a few inces of the top soil and put 2" - 6" of gravel down.
You will get grass eventually even with the herbicide not unless you do it every year with the stuff that kills up to a year.
Hey Everybody Thanks for the info.It is nice to be able to do things like yourself s paying someone.AHHHH Tractors and Equipment SOOOO Much FUNN!!!!!!
/ Box Blade/Driveway Question #8
Oh.. you are paying for it.. it's just that the price of the tractor gets spread out over all the jobs you do with it.
good luck and have fun.
soundguy
/ Box Blade/Driveway Question #9
Planning on doing a similar project after I do some drainage work. Ordering 25 tons of 1 1/2 stone. If I have any left after the drainage, I'll dig down a few inches drop whats left of the stone and finish off with item4.
Lots of good info.So i guess to figure how much gravel i need i take the driveway WXLXD and convert to yards??? is that correct???
/ Box Blade/Driveway Question #12
Cubic yards..
soundguy
/ Box Blade/Driveway Question #13
Length in ft., times width in ft., times thickness in inches, divided by 324 will give you cubic yards. Ask your quarry how many tons per cubic yard and you're all set. I'd scrape off at leat 4"of dirt or even a little more before laying down a gravel base. Oppinions differ but I've had good luck with crusher run 6" deep and after letting it settle and compact, wait for a couple of good rains, dress it with 57's or some sort of finer gravel. Gravel quality varies all over the country and even between nearby quarries. Ask locals what best in your area.
/ Box Blade/Driveway Question #14
Prior to putting down any gravel you might consider putting down some geotextile like fabric. That will prevent the gravel from migrating down into your subsoil and may make for a sturdier surface to drive over. You also may wish to put down more like 12" to 18" of gravel depending on your soil conditions, what type of vehicles will drive over it and how much rain you get where you are located. We have clay where I am and adding rain and melting snow to it makes my gravel driveway (that was not constructed with geotextile or a decent base of 12" to 18" of gravel) a mess. Redoing a driveway, or 30' of a driveway, is probably a lot more work than doing it right the first time. But, your soil, exact use and weather conditons may not warrant geotextile type fabric (comes in 12.5' wide by about 380' long rolls I am told) or more than 6" of gravel. Have fun.
2013 John Deere Hydraulic Grapple Tractor Attachment (A61572)
2013 John Deere...
2023 Caterpillar 259D3 Compact Track Loader Skid Steer (A64194)
2023 Caterpillar...
HOMEADE 101" X 25' TRI-AXLE FIVE SAFETY HOUSE (A63276)
HOMEADE 101" X 25'...
2020 CATERPILLAR CS54B SMOOTH DRUM ROLLER (A65053)
2020 CATERPILLAR...
2018 CATERPILLAR 573D FELLER BUNCHER (A64276)
2018 CATERPILLAR...
IRANCH IRGC40 ELECTRIC SCOOTER (A64280)
IRANCH IRGC40...
