3-Point Hitch bouncing, bad, after repairs were made
/ bouncing, bad, after repairs were made #1
mtlane3795
port jervis ny
kubota l2250
i recently had too take apart the valve body assembly on my l2250. after i put it all back together, the 3pt jumps up and down, sometimes violently. i cant seem to adjust it externally. i already took it back apart and changed some adjustments, it is a little better but not right. is there an easy way to get the adjustments right? or will this be a whole lotta trial and errors before i get this right?
/ bouncing, bad, after repairs were made #2
I don't have the answer but my L3300 is doing the same thing when I lift my rear finish mower. I was hoping it was a relief valve but the service manual is pointing to the 3pt valve body.
/ bouncing, bad, after repairs were made #3
I won't be much help, i can just say my Dad had a way of adjusting something on his ford jubilee when that happened. I know the systems are different but,:2cents:
/ bouncing, bad, after repairs were made #4
I replaced all o-rings for the 3pt valve spoon and the lift cylinder. The bounce went awy and now if I leave the rear mower raised, it will not drift down ever after weeks.
Lincoln Electric Shield-Arc SAE-400 - Radiator Missing - For Parts or Rebuild (A63689)
Lincoln Electric...
213090 (A64276)
213090 (A64276)
2019 KOMATSU D65PXI-18 CRAWLER DOZER (A65053)
2019 KOMATSU...
2003 Dodge Ram 4x4 Ext. Cab Pickup Truck (A59230)
2003 Dodge Ram 4x4...
Hedge Posts (A65640)
2018 FREIGHTLINER CASCADIA 125 6X4 T/A SLEEPER TRUCK TRACTOR (A59908)
2018 FREIGHTLINER...
