3-Point Hitch bouncing, bad, after repairs were made
   / bouncing, bad, after repairs were made #1
mtlane3795
port jervis ny
kubota l2250
i recently had too take apart the valve body assembly on my l2250. after i put it all back together, the 3pt jumps up and down, sometimes violently. i cant seem to adjust it externally. i already took it back apart and changed some adjustments, it is a little better but not right. is there an easy way to get the adjustments right? or will this be a whole lotta trial and errors before i get this right?
   / bouncing, bad, after repairs were made #2
I don't have the answer but my L3300 is doing the same thing when I lift my rear finish mower. I was hoping it was a relief valve but the service manual is pointing to the 3pt valve body.
   / bouncing, bad, after repairs were made #3
I won't be much help, i can just say my Dad had a way of adjusting something on his ford jubilee when that happened. I know the systems are different but,:2cents:
   / bouncing, bad, after repairs were made #4
I replaced all o-rings for the 3pt valve spoon and the lift cylinder. The bounce went awy and now if I leave the rear mower raised, it will not drift down ever after weeks.
1999-2010 Ford Pickup Truck Bed (A55973)
1999-2010 Ford...
2014 Ford F550 (A55973)
2014 Ford F550...
2020 MACK GRANITE (A58214)
2020 MACK GRANITE...
72" HYD QUICK ATTACH GRAPPLE (A51406)
72" HYD QUICK...
2013 Chevrolet Traverse AWD SUV (A56859)
2013 Chevrolet...
2008 Bobcat T190 Compact Track Loader (A56435)
2008 Bobcat T190...
