3-Point Hitch bouncing, bad, after repairs were made
   / bouncing, bad, after repairs were made #1
mtlane3795
port jervis ny
kubota l2250
i recently had too take apart the valve body assembly on my l2250. after i put it all back together, the 3pt jumps up and down, sometimes violently. i cant seem to adjust it externally. i already took it back apart and changed some adjustments, it is a little better but not right. is there an easy way to get the adjustments right? or will this be a whole lotta trial and errors before i get this right?
   / bouncing, bad, after repairs were made #2
I don't have the answer but my L3300 is doing the same thing when I lift my rear finish mower. I was hoping it was a relief valve but the service manual is pointing to the 3pt valve body.
   / bouncing, bad, after repairs were made #3
I won't be much help, i can just say my Dad had a way of adjusting something on his ford jubilee when that happened. I know the systems are different but,:2cents:
   / bouncing, bad, after repairs were made #4
I replaced all o-rings for the 3pt valve spoon and the lift cylinder. The bounce went awy and now if I leave the rear mower raised, it will not drift down ever after weeks.
DEUTZ MARATHON 60KW GENERATOR (A58214)
DEUTZ MARATHON...
2023 Kubota M5660SUH Compact Utility Tractor with LA115-4 Loader (A55315)
2023 Kubota...
2016 Club Car Carryall 710 Electric Utility Cart (A55853)
2016 Club Car...
2017 John Deere 1025R Tractor - 626 Engine Hours (A55315)
2017 John Deere...
2007 DELTA GOOSENECK TRAILER (A58214)
2007 DELTA...
1999 Dodge Ram1500 ST Ext. Cab Pickup Truck (A56858)
1999 Dodge Ram1500...
