Bota floor mat
/ Bota floor mat #1
mbower
North Central PA
Kubota BX2230
Anyone have any ideas to improve the floor mat on the BX. I am going to cut a new mat to cover the unprotected areas and thought I would check out other ideas. Looking for a neat look.
thanks for any ideas
/ Bota floor mat #2
A suggestion that came up in another thread was to use one of the spray on pickup bed linings and to also cover the lower part of the fenders where your feet might rub. I thought that it was a good idea and am planning to do it to my new L3130 due in this week.
Vernon
/ Bota floor mat
Thanks - I also thought of the bedliners. Trying to find a way to protect without changing the paint job from the factory. bedliner probably would work great. thanks again
Matt
/ Bota floor mat #4
"spray on pickup bed linings "
I love the stuff and have had it in my pickup for almost 10 years. It's slippery wet, though. I don't know that I want it as a tractor mat.
/ Bota floor mat #5
</font><font color="blue" class="small">( I love the stuff and have had it in my pickup for almost 10 years. It's slippery wet, though. I don't know that I want it as a tractor mat. )</font>
Isn't some type of "sandy" material spayed in with the bedliner to help with this problem? If not, can it be? John
/ Bota floor mat #6
I don't know. One issue I see is that for it to really work you'd have to expose the grit, and that would make for an abrasive surface. Second, that surface would wear faster than the poly. Seems like the liner would wear faster overall. Just having the grit in there under the surface wouldn't do it. My bed liner is heavily textured and its still slippery. I know people do use bed liner for jeep pans and don't seem to have problems.
/ Bota floor mat #7
Hi...
Cut mat from...
-rubber floor matting... (comes in a roll)
-indoor/outdoor carpet...
-astro turf...
Dave...
/ Bota floor mat #8
I had the guys at Rhino Liner here in WNC to spry mine. I simply removed the platform, washed it off and delivered the platform and original mat to them. They masked off the area the mat covered and taped the holes on the bottom side with metal tape.
Looks great, is NOT slippery at all, and best of all (the reason I had it sprayed) dirt doesn't get UNDER it. I originally thought I would re-install the mat over the rhino to keep the original look, but I like the look of the Rhino.
I'll post pictures when I get home.
/ Bota floor mat #9
OK, so here it is.
/ Bota floor mat #10
</font><font color="blue" class="small">( OK, so here it is.)</font>
Looks excellent! Sure fits in all the crevices nicely. thanks for the pic
John
/ Bota floor mat #11
I just removed the snaps on my floor mat so I can just slip it off for cleaning, That spray job is nice as well.
/ Bota floor mat #12
How hard was the platform to remove? I was gonna do the same thing. Did the fenders have to come off? Can you give us a step by step?
SnailTraX
/ Bota floor mat #13
That is a very neat looking job. I washed the foot platform of my BX22 backhoe today and it is so scratched from my shoes, that the Rhino liner seems like a good alternative to the orange paint that Kubota uses. In fact, my loader bucket is down to the primer on both sides of the bottom. I am tempted to just paint it again for the sake of the tractor looking like new. That is the problem with work vehicles, no matter how careful you are and precautions you take, it will always get scratched or the paint worn off.
/ Bota floor mat #14
</font><font color="blue" class="small">( In fact, my loader bucket is down to the primer on both sides of the bottom. )</font>
Just for grins, I wonder how long the bed liner would last if sprayed on the loader bucket. Probably not long, huh? It might be fun to try but expensive. John
/ Bota floor mat #16
Spray job was about $80. The removal was quite easy. Just a few bolts. The go pedal did have to be removed, but was only two bolts also.
The hardest part was reinstalling it eafter it was sprayed. I had the hole for the brake pedal sprayed over so that I could cut out only as much as needed. After fighting with the hole saw for a few minutes, I decided to just cut a long slit in the general area and slide the pedal thru. There is an open space between the brake and go pedal that has no metal.
/ Bota floor mat
Thanks for the pics and other thoughts. In the end I chose to go inexpensive. Roll of rubber mat traced out by the original mat and adapted to cover the unprotected areas. Then I put the original over the new cutout and secured with replacement clips. I think it turned out perfect for what I wanted. Seams like it will hold up too. For a couple bucks I purchased extra plastic clips so that the mats can be removed occasionally. Here is the pic
/ Bota floor mat #18
</font><font color="blue" class="small">( I had the guys at Rhino Liner here in WNC to spry mine. I simply removed the platform, washed it off and delivered the platform and original mat to them. They masked off the area the mat covered and taped the holes on the bottom side with metal tape.
I'll post pictures when I get home.)</font>
What an awesome idea! I've got the Rhino in my pickup bed, and it's virtually indestructable! I may have to do that myself.
John Deere 980 28' Field Cultivator (A66285)
John Deere 980 28'...
County Line 3Pt Chisel (A66408)
County Line 3Pt...
2018 JOHN DEERE 650K LGP CRAWLER DOZER (A65053)
2018 JOHN DEERE...
2011 AMERICAN 14 T/A DOG HOUSE (A65643)
2011 AMERICAN 14...
Pallet of 12 Metal Shelves (A65579)
Pallet of 12 Metal...
2001 CAT 725 6x6 Water Wagon (A62679)
2001 CAT 725 6x6...
