bobcat 732 engine problem
/ bobcat 732 engine problem
Yes it's closed, I have the air filter off of it right now.
/ bobcat 732 engine problem #22
Is it possible to place your palm over the throat of the carb for a few seconds while rolling over, to check for vacuum, & see if it will pull fuel that way..??
Spark advance port plugged..?? No tears, or tiny pieces of the body gasket missing around the tiny internal passages..?? The Holley on my Ford 3 cyl. had a tear in the body gasket, and was doubled over, leaving maybe a 1/8" air gap, where a PO had apparently had it apart before. Had to choke it forever to get it started, then would surge. Glued it back in place with some gasket sealer, and eliminated the problem.
/ bobcat 732 engine problem #23
did you ever find your problem. I think I am having the same issue
/ bobcat 732 engine problem #24
I have a 732 with Ford 1.6 engine , cranks good but won’t start.
just wondering if you got it running and what you did.
New/Unused CFG Industrial MH12RX Mini Excavator (A65583)
New/Unused CFG...
2009 Arco Trailer 6,000 Gallon T/A Tank Trailer (A61568)
2009 Arco Trailer...
RIDGID AIR COMPRESSOR (A65643)
RIDGID AIR...
2012 Buick Enclave (A62613)
2012 Buick Enclave...
2017 Chevrolet Tahoe SUV (A64194)
2017 Chevrolet...
SHOPBUILT TRI-AXLE COMBINE HI-CYCLE TRAILER (A63291)
SHOPBUILT TRI-AXLE...
