Big Enough Truck?
/ Big Enough Truck? #121
I'm thinking of buying a 25ft trailer with 10K tandem axles. If I have that trailer fully loaded (nearly 20K lbs.) will my F-250 with 7.3 Power-Stroke diesel be enough truck?
All of this CDL/Non CDL, commercial/non commercial, GCWR discussion aside, no.
An F-250, stick will not have the gears to sustain that type of duty and an automatic will not last long. Handling and stopping wise, you are going to have to be very mindful of what is going on. That can take a toll.
/ Big Enough Truck? #122
So let me get this straight
Are they then going to restrict your "B" also?
Would make for an odd looking license if you had a standard "B" with a restricted"A"
From what I've read or been told, it's up to the driver to decide which is gotten. But you cannot have a Class B with Air Brakes and a Class A without at the same time. It's one or the other. If you want a Class A for trailers over 10K and want to drive a Class B truck with Air Brakes, you're going to have to get a Class A CDL with no Air Brake restrictions. If you get the Class A and don't get the Air Brake part, you'd lose the Air Brakes accross the board.
YALE 60 MX STRAIGHT MAST FORKLIFT (A63276)
YALE 60 MX...
208315 (A58376)
208315 (A58376)
2002 Bobcat 863 High Flow Compact Wheel Loader Skid Steer (A61567)
2002 Bobcat 863...
2006 Ford F-150 Lariat (A57148)
2006 Ford F-150...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2025 Unused SDLGC80 60v Electric Golf Cart (A60352)
2025 Unused...
