Best way to install T-posts
   / Best way to install T-posts #1
CMV
Platinum Member
NC
Kioti NX4510HST (previous LS XJ2025H, JD 500C)
And what size.....???
I'm going to hang steel targets along a winding 250 yd path I cleared along a creekbed with real high natural berms. Idea is to have a long lane you can walk down and engage targets with pistol, PCC, or AR with 22 conversion kit. Not going to be centerfire rifle distance. I'm thinking best way to do this would be 10-12" gongs with 1 hanging hole and use the T-post target hangers similar to Amazon.com: Steel Target Hanger, T Post AR5 / A36 Plate Mount: Home Improvement. Problem is the ground is pretty rocky and the hillside has lots of roots, vines. Just get a T-post driver at TSC and hammer away or is there a better way? Probably do about 25, and add on as funds for more targets available over time. Otherwise, I won't be installing T-posts for anything else - not doing a fence or anything later on.
The T-posts at TSC range from 3' to 10'. Ideally I'd want the target about 3-4' high. So does the size of the post mean once you drive it in the ground there is that much still sticking up? i.e bury the ears of a 4' post and the top is 4' above ground level or there's only 3' remaining above ground because you buried 1'? Seems to be 2 flavors - studded & light duty. Since I'm not trying to make a fence with livestock leaning against it, I'd want the light duty ones? Or I need the heavier ones so they don't get mangled if they hit a rock while driving into ground or don't rust away quickly?
And then real dumb question.....can I just get it started then just push it in with tractor bucket or do I just need to keep pounding them with the post driver until deep enough?
   / Best way to install T-posts #2
Try driving one into the ground with the side of a slug hammer first.
I would think real rocky ground would be very tough to do.
go to a place that sells fence posts and pick out one that looks like the length you need.
   / Best way to install T-posts #4
The T-post drivers that they sell at TSC work really well. They're basically a heavy pipe with handles and a spring inside. I've put in HUNDREDS of T-posts with those T-post drivers.
   / Best way to install T-posts #5
You can theoretically use your bucket to push them in, the problem is that the loader travels downwards as well as forward and back in an arc as it goes down so you have to carefully move the tractor forward and backwards to keep the post straight. You would also want some way to bolt on a cup or something to the bottom of the bucket to keep the t-post from slipping.
You might try taking a 8 inch piece of pipe, welding a three or four inch piece of flat stock to the top of it sticking up and putting a large bolt through that and into the side of your loader bucket so that the piece of pipe can remain vertical through the entire travel of loader.
Aaron Z
   / Best way to install T-posts #6
I installed a t-post and welded wire fence around the back of my property a few years ago. Used a post driver, same as RichZ describes except no spring inside. It worked fine. Got everything from tractor supply.
   / Best way to install T-posts #7
Believe you will find the length of the post is the over all and not the net height. Also if me I would not use the light duty post for the rocks, roots and bullets. You will be shooting basically the same area on the post even a 22 over enough rounds I believe will damage the light duty post. They are not hitting an angle surface to slid off of. Not meaning to insult your accuracy but we all miss, some more than others.
   / Best way to install T-posts #8
The indicated length of a T-post is the total length. 6 1/2' post driven 1 1/2' into the ground will have 5' exposed above ground.
You aren't going to be driving enough post to get fancy. Use the flat side of a 4# or 6# sledge hammer.
When I fenced my 80 acres I drove 675 T-133 posts with a home made manual driver. 1 1/2 miles of fence line.
   / Best way to install T-posts #9
If you can weld, you could weld like a steel cup on the back side of your FEL, about where it turns upwards so it'd be mostly out of the way when using the FEL scooping. Then place the cup over the end of a started post and push down with the FEL.
Preferably, you want to sink the posts to the top of the arrow that's placed on them.
Ralph
   / Best way to install T-posts #10
I'm really surprised anyone sells a target that mounts to a metal post. Miss the target, hit the angled part of the T-post and watch out for the ricochet.
I don't know your layout but I would not have metal behind targets I am shooting at. I've had some pretty weird ricochet off of rocks and that was enough for me. Those rocks were behind a paper target supported by wood posts.
2018 Husqvarna 21in. Push Mower (A59231)
2018 Husqvarna...
V.E. ENTERPRISES 500 BBL FRAC TANK (A58214)
V.E. ENTERPRISES...
2018 KOMATSU D65EX-18 CRAWLER DOZER (A60429)
2018 KOMATSU...
5' ROTARY MOWER (A52706)
5' ROTARY MOWER...
2009 PETERBILT 340 WATER TRUCK (A58214)
2009 PETERBILT 340...
bad boy zero turn 72 (A56859)
bad boy zero turn...
