And what size.....???
I'm going to hang steel targets along a winding 250 yd path I cleared along a creekbed with real high natural berms. Idea is to have a long lane you can walk down and engage targets with pistol, PCC, or AR with 22 conversion kit. Not going to be centerfire r**** distance. I'm thinking best way to do this would be 10-12" gongs with 1 hanging hole and use the T-post target hangers similar to
Amazon.com: Steel Target Hanger, T Post AR5 / A36 Plate Mount: Home Improvement. Problem is the ground is pretty rocky and the hillside has lots of roots, vines. Just get a T-post driver at TSC and hammer away or is there a better way? Probably do about 25, and add on as funds for more targets available over time. Otherwise, I won't be installing T-posts for anything else - not doing a fence or anything later on.
The T-posts at TSC range from 3' to 10'. Ideally I'd want the target about 3-4' high. So does the size of the post mean once you drive it in the ground there is that much still sticking up? i.e bury the ears of a 4' post and the top is 4' above ground level or there's only 3' remaining above ground because you buried 1'? Seems to be 2 flavors - studded & light duty. Since I'm not trying to make a fence with livestock leaning against it, I'd want the light duty ones? Or I need the heavier ones so they don't get mangled if they hit a rock while driving into ground or don't rust away quickly?
And then real dumb question.....can I just get it started then just push it in with tractor bucket or do I just need to keep pounding them with the post driver until deep enough?
I have used a hand post driver tool to drive T post (well maybe the wife has used it) and 2" diameter wooden garden area post, and it's not easy in Montana because there is a reason they call it the "Rocky Mountains".
At our gun club range we have large steel frames made out of 4" x 4" x 1/4" angle iron showing the legs at a 45 degrees from the shooting area.
We hang 2 sheets of 4' x 8' OSB on the inside of the frames with chain, and the steel frames get shot up like Swiss Cheese until they fall to the ground.
Then we repeat the process to fix the targets.
I have made my own portable target stands for paper and steel targets to use at our gun club range and made up a similar tube steel target holder (that you have linked above) for each of my AR500 targets, but now I just hang the targets from a piece of 3/16" welded chain with "S" hooks.
If it were me I'd used the KISS method for each target:
A 6" piece of rectangular tube steel 4" x 2" x 1/8" and weld on two sides a 18" piece of 1/2" rebar, and paint it, and pound this into the ground (if the wood is to loose for you, just shoot the steel tube a few times as needed).
Then I would use 4' pieces of 2 x 4 wood that just slips into the tube steel next to the ground.
I would then take a 3/8" piece of rebar about 12" long and bend a "V" shape on one end, drill a hole near the top of the 2 x 4 for a snug fit, pound the rebar into the wood and hang the steel target.
This or a similar system would allow for low cost and easy replacement as needed.
Just a thought, good luck,
KC
Oh, and I did try using my bucket to drive the T post, does not work on my property.
