Best way to cut large tire in half?
   / Best way to cut large tire in half? #1
AaronD81
PA
Kioti CK30
I want to cut a large (70in diameter) tractor tire in half (two half circles) for goat toys. What's the easiest way to do this? Angle grinder or sawzall? What type of blade? Something else? A demo saw would probably be fastest but I don't feel like renting one just for this.
   / Best way to cut large tire in half? #2
I'd go for the angle grinder, at least on the bead. The tractor probably has metal wires in the bead. After you get through the bead, maybe a sawzall might be better, or perhaps a skill saw. It is going to be a stinky job if you have to use the angle grinder all the way but it will probably be the best quality cut.
   / Best way to cut large tire in half? #3
Agree with Cougsfan - I used a Sawzall to try and cut a rear tire from a ZTR off the rim, but the wires in the bead were too much for the Sawzall to handle. Angle grinder would probably be the quickest.
   / Best way to cut large tire in half? #4
my go to would be a skill saw with a 40-tooth blade and an angle grinder with a very thin cut off wheel... I don't think a sawzall would work too well...
   / Best way to cut large tire in half? #5
I would bury 1/2 into the ground so the goats can play safely.
   / Best way to cut large tire in half? #6
I've done this with a sawzall. I think the angle grinder would gum up and smoke like heck.
   / Best way to cut large tire in half? #7
I see people online cutting them with those vibrating cutters with zero smoke. Seems like the way to go.
   / Best way to cut large tire in half? #8
Angle grinder will generate lots and lots of smoke and really really stink! BTDT, but it does work and makes a reasonably nice cut edge. The wires are still going to stick out a little ways (like 1/16") or so.
   / Best way to cut large tire in half? #9
I would try the sawzall, keep it lubed with a squirt bottle filled with soapy water.
   / Best way to cut large tire in half? #10
Sawzall with a metal cutting blade.
2003 Ford F-150 Pickup Truck (A48081)
2003 Ford F-150...
2018 Kubota RTV 850 4x4 (A48837)
2018 Kubota RTV...
2003 Land Pride 4x4 Utility Cart (A49346)
2003 Land Pride...
2010 Icon LT-A617.4+2G Electric Golf Cart (A48082)
2010 Icon...
2022 Ford F-150 4x4 Crew Cab Pickup Truck (A48081)
2022 Ford F-150...
UNUSED LANDHONOR SKID STEER PALLET FORKS (A50460)
UNUSED LANDHONOR...
