Best way to cut large tire in half?
   / Best way to cut large tire in half? #1
AaronD81
PA
Kioti CK30
I want to cut a large (70in diameter) tractor tire in half (two half circles) for goat toys. What's the easiest way to do this? Angle grinder or sawzall? What type of blade? Something else? A demo saw would probably be fastest but I don't feel like renting one just for this.
   / Best way to cut large tire in half? #2
I'd go for the angle grinder, at least on the bead. The tractor probably has metal wires in the bead. After you get through the bead, maybe a sawzall might be better, or perhaps a skill saw. It is going to be a stinky job if you have to use the angle grinder all the way but it will probably be the best quality cut.
   / Best way to cut large tire in half? #3
Agree with Cougsfan - I used a Sawzall to try and cut a rear tire from a ZTR off the rim, but the wires in the bead were too much for the Sawzall to handle. Angle grinder would probably be the quickest.
   / Best way to cut large tire in half? #4
my go to would be a skill saw with a 40-tooth blade and an angle grinder with a very thin cut off wheel... I don't think a sawzall would work too well...
   / Best way to cut large tire in half? #5
I would bury 1/2 into the ground so the goats can play safely.
   / Best way to cut large tire in half? #6
I've done this with a sawzall. I think the angle grinder would gum up and smoke like heck.
   / Best way to cut large tire in half? #7
I see people online cutting them with those vibrating cutters with zero smoke. Seems like the way to go.
   / Best way to cut large tire in half? #8
Angle grinder will generate lots and lots of smoke and really really stink! BTDT, but it does work and makes a reasonably nice cut edge. The wires are still going to stick out a little ways (like 1/16") or so.
   / Best way to cut large tire in half? #9
I would try the sawzall, keep it lubed with a squirt bottle filled with soapy water.
   / Best way to cut large tire in half? #10
Sawzall with a metal cutting blade.
2019 Allmand Light tower (A49461)
2019 Allmand Light...
2025 Future Stump Grinder Mini Skid Steer Attachment (A50322)
2025 Future Stump...
2020 KUBOTA SSV75 WHEELED SKID STEER (A51242)
2020 KUBOTA SSV75...
24in Tractor Backhoe Bucket BT4555 (A51039)
24in Tractor...
Kenco PH9000 Self-Leveling Pipe Hook - 9,000 LB Capacity, 8FT Max Pipe Length (A51039)
Kenco PH9000...
2020 MACK PINNACLE (A50854)
2020 MACK PINNACLE...
