Batwing for JD 5083e?
/ Batwing for JD 5083e? #1
jjswag
TX
None
Getting close to my tractor purchase and want to know if anyone is using the mx15 with the 5083e?
My JD dealer states that the largest cutter recommended for the 5083e is the mx10 pull type which is hard to believe. Is anyone using a 15' cutter by another manufacturer with this tractor?
Thanks!
/ Batwing for JD 5083e? #2
i pull a 15 foot bush hog cutter with a jd 5510.it handles it good.a 5510 is a older model tractor the same physical size , but with 10 more pto horsepower.if you have hills,get rear wheel and front weights.a 5083 should be big enough .you will have to slow down if the grass is thick.
Thanks cowski......our new property is all flat and I will just be keeping the light pastures mowed and and will soon have some cattle. I was also looking at a mahindra 8560, but the dealer says that the mahindra 6010hst or 6110 shuttle would be perfect. They say these tractors will handle a 15' batwing and move round bales with no problem.
/ Batwing for JD 5083e? #4
Bat wings are overrated unless you are mowing LOTS of acreage. You need at least 100 pto hp to pull one. Get a Deere HX-10 for less than half the money. That's what I use. I used to have a bat wing but I'm glad it's gone.
I'll be mowing 70 acres, but only 25 acres at a time.
/ Batwing for JD 5083e? #6
I don't agree that you need 100 PTO HP for a batwing.
I just bought a used 15' Rhino to use with my 84 PTO HP tractor. I've mowed some half way steep ground, no problems with power or weight.
I have also mowed some extremely steep and rough places that required a 100 PTO HP tractor for a 10' cutter, for both weight and power.
Since you're just clipping pasture I feel that a 15' would work well with that tractor.
I will agree that new they are twice the cost of a 10' unit.
/ Batwing for JD 5083e? #7
They mow the field grass at work with a kubota m9540 85ish pto hp and what looks to be a 15foot batwing on hills without any problems. they maintain hundreds of acres. They also have a bigger NH 6000 series. I think they probably mow 40 hours a week in the spring and fall. The facility is several thousand acres. The grass does not usually get over knee high
/ Batwing for JD 5083e? #8
Check out my "bush hogging pictures" in my signature if you want to see some "hills". lol
/ Batwing for JD 5083e? #9
Hi You should be fine , like others have said u might add some weights to the tires (fluid ,or bolt on ) .But if your ground is not real steep and the grass etc is not too heavy , u should be able eat any thing you run over. I was going to buy a John Deere HX 15 then decieded on the MX 15, after looking at my ground and knowing the ground from past mowing , and the filth (heavy) I went with a John Deere HX10 pull type . I like it , its not 15ft but the ground Im mowing is not level ,far from it and not smooth.Im pulling it with a John Deere 5093e with FEL . Every once in awhile I wish I would have bought th 15 ft ! But the 10 ft does the job and I know Ive got enough tractor to do what i want, and like they say it was half the $$$$$$! just my 0.02cts have a good one!
Thanks for the information....How do you like the 5093e...would you buy it again?
/ Batwing for JD 5083e? #11
Your Welcome.
As far as how do I like the 5093e? I like it for what it is, by that I mean it will do the work I do . I was wanting something in this size machine when I bought it , I listened to several people ,and the dealer etc...... But I found out this tractor is good but has some faults IMO. Ive stated on here before (different posts) the hydraulics seem slow and weak to me. The tractor as a whole is lighter then I thought ,even after fluid all 4 tires, and 4rear weights. Im packing a 553 FEL which is ok , the bucket is a little overkill also. Maybe I think that because of the Hydraulics I dont know. I do know that Ive run several tractors and I run heavy equipment, based on that IMO as Ive stated before this series of John Deere tractors IMO is overrated. I would have to think long and hard before I bought another , I would go to the M series Im almost sure . The M is more $$$$$$ but after working this machine ,IMO its worth it. I guess Im at fault also I didnt do enough HOMEWORk ! LOL kinda like when I was in school! LOL. I was always told YOU COULD DO BETTER......... LOL.O well for the time being it will have to do. Have a Good 1
/ Batwing for JD 5083e? #12
Around here years ago several counties around here pulled 15' batwings with John Deere 5400 tractors and you have more power than they do. Granted they was not in material much over three feet tall but they did okay. If your mowing tall heavy material it's nice to have at least 80 pto horsepower minimum. I use to pull a 15' years ago with a John Deere 4650 fwa and it was overkill.
2022 EZ-GO ELITE...
2019 Cadillac XTS Stretch Limousine for Sale, S and S Coachbuilders, 70IN, 7866 Miles (A63688)
2019 Cadillac XTS...
New/Unused Landhonor 6ft x 8ft Galvanized Apex Roof Metal Shed (A65583)
New/Unused...
New/Unused Quick Attach Hydraulic Rock Hammer (A65583)
New/Unused Quick...
1978 Fruehaue Chipper Trailer (A62613)
1978 Fruehaue...
2021 John Deere 50G Mini Excavator (A62613)
2021 John Deere...
