battery problems onL2550
/ battery problems onL2550
not going to have a chance to try this last post for a few days but will post results when i can.Do i unplug the regulator and do the jumper wire on the alt. with the plug still attached to the alt.?? Thanks for all the help so far.............
/ battery problems onL2550 #22
Just so you know, "geneo", I had the exact same problem with my 2550,
I even changed out the regulator with a new one.
I didn't change anything. When running, your tractor should be reading at least 13.5 volts.
Ideally, it should read 14.5, the voltage your reading sounds like the battery voltage.
Test your car battery for fun and compare.
Test it running and then with the key off and you'll see what I mean.
/ battery problems onL2550 #23
You could. ... I was thinking to unplug the connector from the alt and feed 12V to the spade lugs on the alt corresponding to the blk [-] and wht/grn [+] wires. ... Either way you eliminate the chance of feeding back to the Vreg. I havnt seen mine. Is it up under the dash somewhere?
larry
2018 CATERPILLAR TL1055D TELESCOPIC FORKLIFT (A62129)
2018 CATERPILLAR...
Case IH 5100 12ft. Soybean Special (A65640)
Case IH 5100 12ft...
Mobark Beever M12RX Wood Chipper (A65579)
Mobark Beever...
Greenworks Commercial 82V Utility Vehicle 500 CAMO Model: U500SC - DEMO UNIT (A63689)
Greenworks...
2025 SDLANCH IRGC40 Two-Seat Electric Tricycle (A64194)
2025 SDLANCH...
2005 Chevrolet C7500 20' Box Truck (A62613)
2005 Chevrolet...
