battery problems onL2550
/ battery problems onL2550
not going to have a chance to try this last post for a few days but will post results when i can.Do i unplug the regulator and do the jumper wire on the alt. with the plug still attached to the alt.?? Thanks for all the help so far.............
/ battery problems onL2550 #22
Just so you know, "geneo", I had the exact same problem with my 2550,
I even changed out the regulator with a new one.
I didn't change anything. When running, your tractor should be reading at least 13.5 volts.
Ideally, it should read 14.5, the voltage your reading sounds like the battery voltage.
Test your car battery for fun and compare.
Test it running and then with the key off and you'll see what I mean.
/ battery problems onL2550 #23
You could. ... I was thinking to unplug the connector from the alt and feed 12V to the spade lugs on the alt corresponding to the blk [-] and wht/grn [+] wires. ... Either way you eliminate the chance of feeding back to the Vreg. I havnt seen mine. Is it up under the dash somewhere?
larry
2009 JACK COUNTY KILL TRAILER (A58214)
2009 JACK COUNTY...
T/A16ft Enclosed Trailer (A61569)
T/A16ft Enclosed...
2020 CHEVROLET SILVERADO CREW CAB TRUCK (A63276)
2020 CHEVROLET...
2015 Ford F-150 Ext. Cab Pickup Truck (A61568)
2015 Ford F-150...
(APPROX. 35) DIAMOND PLATE DBL AXLE FENDERS (A62131)
(APPROX. 35)...
Year: 2021 Make: Chevrolet Model: Express Vehicle Type: Van Mileage: 86,989 Plate: Body Type: 3 D... (A61568)
Year: 2021 Make...
