Battery powered chainsaw
/ Battery powered chainsaw #121
I have a Sthil 140c. It has a 12” bar and a Picco chain. It’s great for limbing small trees or keeping handy while running the tractor for limbs and chopping up small stuff that’s in the way. I’m very happy with it knowing it’s size and limitations. Where this one shines is trail maintenance. Small and light to carry, but way easier to get fallen logs out of he way over a hand saw. And no noise. Battery lasts about what a tank of fuel would.
/ Battery powered chainsaw #122
I love the smell of two stroke in the morning...
I hope this trend continues with battery, it should bring some good old powersaws to market. Then I can scoop them off you old farts.
/ Battery powered chainsaw #123
who owns owns one ? Brand ?
I've had a Greenworks 16in 40v battery chainsaw for years. I heat my 2300 sq ft house with wood, and that's the saw I use. Not perfect, uses up batteries fairly quickly (I have 6), but I'm always cutting wood. No problem starting it up, the chain stops when you release the trigger, and its very quiet so I don't need ear protection. I hate loudness of any kind. It's a useful tool.
Having said that, when I fired up my 20" gas Stihl, it was very easy to go through some big stuff, and quickly. For some reason, though I can't get it to start now.
/ Battery powered chainsaw #124
You've managed to respond several times to this thread without adding anything but snarky comments. Ever use a battery powered saw? Perhaps you should invest in some two stroke drills and impact drivers while you are at it.
/ Battery powered chainsaw #125
BTW...if anyone has a Stihl 076 super...take my money.
/ Battery powered chainsaw #126
Thanks for being observant. And yes, I have used a battery saw. I think it doesn't take a rocket scientist to figure out I was not impressed.
/ Battery powered chainsaw #127
I have a Stihl MS120c. It's small, but great for limbing, and trimming, and will take down the occasional 4-8" tree. The bar is 12" with Picco chain, so it can't be rushed, but it has never not ripped into stuff with more gusto than I imagined. I'm happy. And, that battery life is surprising.
/ Battery powered chainsaw #128
My son purchased an EGO saw, as he already had an EGO mower, hedge trimmer, and blower. I got to try it out last fall, and I was impressed with it, after I sharpened the chain. It had a really good bite and cut, and the battery went for quite some time, and when I put it back on the charger, it showed only 80% used. Pretty good for over an hour of cutting up a small 8" apple and limbs. However, I was not impressed with the bar. It was thin and in my estimation, quite flimsy. I could see a good pinch making it nearly worthless in a heartbeat. I can see battery saws in use in and around a home or camp site. They are easy, clean and quiet. I can also see their use as for FD and rescue, as many of those vehicles have build in A/C power, to keep batteries up to snuff. They also might be useful as a tool on a tractor/snowmobile/ATV. However, for serious loggers, power line work, disaster clean up and such, I think you will see gas saws will live a long time.
/ Battery powered chainsaw #130
I had always used 2 stroke chainsaws but kept an eye on the development of the battery saws. It was enlightening to purchase a Makita battery powered impact gun for lug nuts and big jobs around the place, since it was more powerful than my air tools and way more portable.
I had the chance during "snowmaggedon" the winter of 20-21 here in Texas where it got too cold for my 2 stroke saw to run well, and we needed more wood. Went down to Ace Hardware and picked up an EGO saw to go with my blower and proceeded to cut over a truckload of dry wood with ease. Not sure what was wrong with my Stihl, since it usually runs well and I was running good non-ethanol fuel, but it just didn't work.
Since that time, I've used the snot out of the EGO saw, since it is way lighter than my farm boss, quieter, easier to use, etc. Cleared a bunch of cedars behind the house and cut a bunch of firewood. It's amazing actually.
And if it quits working in a few years and I can't get a new battery for it, I'll either go back to using my 2 stroke or buy whatever new improved saw that has come out to replace it. The labor and hassle saved is already worth the price I paid, not to mention the fact that I was able to heat my home for several days when I really needed it. It works fantastic for me.
It is interesting how many different kinds of battery saws people have mentioned using, and almost all are happy with their choice. That would indicate battery power is a superior technology for at least one segment of the saw market.
/ Battery powered chainsaw #131
I have a 16" Craftsman battery chainsaw with two batteries. Works great for cleanup around our 7.5 acre place. It's a narrower gauge chain than my gas saws, which helps with cutting speed. With the two batteries, it runs longer than I care to be using a chain saw in one day. (And I can go longer if I put the first battery back on the charger). I no longer use the gas saw, and won't buy another (or other gas small engine tool, for that matter). I love that I never have to worry about it starting, no matter how long it has sat unused. The environmental benefits are meaningful, too.
/ Battery powered chainsaw #132
I have a Greenworks 16 inch saw with a 40v 4amp battery. I am very pleased with its performance. Works great on small acreage I have. It's nice to use a battery and not have to mix gas and oil. I keep an extra battery for jobs that require a lot of time cutting. The length of battery time depends upon the stress the saw is under. For the most part, a battery charge lasts 30-45 minutes. Good luck.
/ Battery powered chainsaw #133
I have the 16 and 18 inch EGO saws, mower, and power head with string trimmer and hedge trimmer attachments. As for the batteries, I'm not concerned as to future availability. The EGO battery ARC technology, in my opinion, seems to be superior due to design. https://egopowerplus.com/innovation
/ Battery powered chainsaw #134
I've not sprung for an electric chainsaw as yet, but I use a Milwaukee M18 Sawzall with a Diablo carbide pruning blade for cutting down brush rather than my 20" Stihl gas saw. It's much safer, of course, especially in difficult conditions, and is ideal for getting out roots since the blade doesn't mind grubbing in the dirt and they're not expensive to replace when that becomes necessary. It's particularly effective at cutting out ocean spray; I have lots that's 2-3 inches in diameter and is as hard as anything.
/ Battery powered chainsaw #135
I have a Dewalt 60V and I wouldn't trade it for anything. I used it to clear saplings from a neglected fenceline before I re-fenced it. I got great battery life and saved a lot of elbow grease since it was a lot of start and stop. I also used it to help a neighbor with a large fallen cedar tree and he liked mine better than his gas. It has its limitations and I wouldn't use it for pro work like lumberjacking, cutting a lot of firewood or clearing. But, it's more than proven it's worth to me. Buy extra batteries. They are expensive but better than waiting for those big monsters to recharge. I kept 3 in rotation. By the time I had none available, I was ready for a short break.
/ Battery powered chainsaw #136
I own a Kobalt 80V chainsaw as well as the corresponding 10' limb saw. I currently own 2 batteries and if cutting something like a 12-14" tree and a new/newly sharpened chain I can get through it with one + battery charge depending on the tree species. the harder the wood less cutting it can do before running out. Just aftr I got it I decided to tackle a tree about 24-30" and only got about halfway done with both battries. I was also at the point that I had to continue due to where it was and where I needed it to fall. I had to get out the gasser to finish the job. I like my battery chainsaw as I don't need to get out gas and mix etc. It is convenient and works for most things I need to cut and any more the length of time this old body can stay with it as well. I find 2 batteries worth is about all I want to use in one day. Like I said for most of what I need to do my Battery powered saw is the tool I use most these days. If you are going to be cutting for more than about an hour straight you need to go to a gasser. I usually cut maybe for an hour and re-charge batteries while i do something else so for me it makes sense. Also as long as the chain is sharp mine cuts extremely well and of course the batteries last longer. Hope this helps!
/ Battery powered chainsaw #137
If you already own battery powered tools, I would stick with one brand's platform. That way, all your batteries work with all the tools in that platform and you're not having to stock 50 different chargers and sets of batteries. For lawn and garden, I began with the WORX platform and now have their chainsaw. It works pretty well for small jobs. I have noticed, however, that the chain can jump off the bar when cutting really small branches. Someone mentioned that you have to monitor the tension and maybe that's what I need to do every time I stop the saw. You can't have a slight sag in the chain as you do for a gas powered saw. For bigger jobs, I would use my gas powered Stihl.
/ Battery powered chainsaw #138
EGO battery chainsaw here. Works great & have bought other EGO tools which all also work beyond my expectations. I have 4 Still gas saws and I haven't used them in 2 years because of how well the EGO saw works. I have 2 batteries. Only cut one tree up at a time these days so don't need the gas saws any longer.
/ Battery powered chainsaw #139
Bought the wife a gas Stihl string trimmer, always had trouble starting it. Got her the EGO 56v trimmer now her and the battery run out of power about the same time. She had a light weight easy start Stihl chainsaw, same problem, always had trouble starting it (operator errors) bought her the EGO chainsaw now its just put the battery in and pull the trigger. Great things.
/ Battery powered chainsaw #140
i have several Ryobi saws, pole saw, weed trimmer, leaf blower all use 40 volt batteries. the saws are great for cutting limbs after dropping a tree, really handy around the saw mill and much safer. As long as you keep them sharp they cut good
2020 Cat 302.7D Mini Excavator (A64047)
2020 Cat 302.7D...
2016 Ford Explorer AWD SUV (A66738)
2016 Ford Explorer...
2024 BOBCAT CT2025 TRACTOR (A65057)
2024 BOBCAT CT2025...
2009 FORD E350 CARGO VAN (A66091)
2009 FORD E350...
2006 SUPERLINE DO20T192ALP T/A 20FT TRAILER (A66091)
2006 SUPERLINE...
2014 MAC FLAMELESS HEATER TRAILER (INOPERABLE) (A67714)
2014 MAC FLAMELESS...
