Battery powered chainsaw
/ Battery powered chainsaw #881
Data. Well I use both side by side. I can cut for nearly an hour on my 40cc Echo. I can cut for maybe 20 minutes with the Greenworks Pro with a single battery. The battery weighs a helluva lot more than those few ounces of fuel. Carrying a can of premix that weighs less than ONE battery, will keep me cutting for hours, whereas that battery will get me 20 minutes into a tree.
There really is no comparison when it comes to weight and runtime with a battery as opposed to the same weight in fuel. None.
/ Battery powered chainsaw #882
I’m pleased with my the AP battery saws.
Thanksgiving to Christmas the farm sells about 3300 Christmas Trees.
Each tree is at least one fresh cut and for years that was with Stihl gas saws and 3300 starts is very hard on the 2 gas saws…
Bought the first battery saw and it quickly became the only saw everyone wanted and one charge would last all day… no servicing other than chain oil and adjust tension.
The gas saws had carb issues as well as rope pull cord and spark plugs… plus no more mixing oil and gas.
Every winter storms topple oaks across the trails and I don’t even bring the gas saw out to clear…
/ Battery powered chainsaw #883
The Stihl battery saws are around $400+ for the saw. One AP300S battery is about $300. So, a $700 investment that requires you to stop and recharge every 30 minutes?
I suppose there are a lot of situations where you may only want to cut for 30 minutes at a time. Our use is just much different. We travel hours with a crew to work 7-8 hour days cutting and clearing. We all volunteer our time, so we try to be as effective as possible, while we are on site.
/ Battery powered chainsaw #884
A small can of gas weighs less than a battery, and that can will last 8 hours or more.
Why is the minor weight difference an issue? I often carry a second battery in my pocket, but wouldn't consider carrying a container of gas that way.
I have a 12V fast charger and recharge a spare battery in my truck. That way, I can cut all day if necessary, using 2 or 3 batteries. All my cordless tools use the same type battery, so there are always a few laying around that are ready to go.
Don't get me wrong, an electric saw won't completely replace my gasser. However, it will do 70% of the work I do around the place, without the hassle of mixing and clearing fuel from the saw.
An electric saw is simply an addition to my tool collection.
/ Battery powered chainsaw #885
That's the same as we found. The battery saw is right tool for many jobs, but not all of them. But not all day for hours of cutting.
/ Battery powered chainsaw #886
If we could reliably charge near our cutting site, and carry a couple batteries per saw, and have one charger per saw, it would work just fine. As it stands, one sawyer, one saw, one 32oz can of premix and they are good for a days worth of cutting. My pockets aren’t big enough for a battery or a can of fuel.
Even at home, I find myself grabbing my Echo on my property. Because I know I can take a small can of fuel and cut as long as I’d like. If I take the battery saw, I’m going back to the shop 1/4 mile away at times, to place the battery on a charger and wait. Unless I invest in more $200-$300 batteries.
I can almost buy another saw for $300
/ Battery powered chainsaw #887
Some folks don't seem to comprehend just how much power or fuel takes to run these gas saws all day long. Its a bit. When we carry fuel onto the trail with backpacks, we use these MSR bottles in the 20oz version. Without the safety cap.
/ Battery powered chainsaw #888
Data, please. Don't just "probably" make things up.
I did. See post #869 on the prior page. Ignoring relative efficiencies, it's a 110x ratio. We know the battery saw has much higher efficiency than an ICE, but what's the gross ratio? Even if the ICE is only 30% and the battery saw is 90%, that only takes the 110x input efficiency down to 37x output efficiency difference, measured as wood cut per pound of fuel carried.
I don't think it is, if the intended usage is within the capacity of one or two battery packs. The convenience of the battery saw can easily justify the small added weight.
But when you get to the amount of all-day cutting, where you might be consuming a half gallon of fuel, then you need to start counting your battery packs by the dozen. The battery saw loses practicality when you're slinging a long bar thru big oak, something that can easily chew thru 1/2 gallon or more of fuel in a day.
The easy answer is, you should own both! :D Battery saw for quick limbing jobs and pruning around the house, with the fleet of gassers for when you're going out harvesting, for those of us heating our homes with wood or harvesting for woodworking.
/ Battery powered chainsaw #890
I don't think comparing battery weight to gas weight means anything. An electric saw without the battery is lighter than a gas saw with an empty tank.
It matters when you consider refuel weight and bulk. How much liquid fuel do you need to cut 3 hours?
How many 4 pound batteries do you need?
My battery saw weighs more with 30 minutes of runtime (battery installed) then my gas Echo full of fuel.
/ Battery powered chainsaw #891
Except that an empty gas tank or without a battery is not how you use the saw. I own 1 battery chainsaw and 3 gas saws.
My Milwaukee electric saw is about the equivalent of a 40cc gas saw. Its spec. weight is 13.9 lbs without the battery. The 12 AH, high output battery weighs 3.4 lbs. That's 17.3 lbs total without bar oil. (It's not clear if the Milwaukee weight spec is for PHO or includes the bar and chain. I'll assume they are included.)
My smallest gas saw is my old 50cc Jonsered 2152. weighs 11 lbs (powerhead only). A full tank of fuel (16.9 fluid ounces) weighs 0.8 lbs. The 16" bar & chain adds about 1.0 lbs. This gives a total weight without bar oil of 12.8 lbs.
The Jonsered 2152 will cut rings around the Milwaukee M18, will run much longer without refueling/recharging, and weighs 4.5 lbs less.
I use different saws for different applications. There are times I prefer the Milwaukee M18. It's great when noise is an issue (when I don't want to disturb the neighbors, or when cleaning up the outdoor classroom area behind the local elementary school). It can be more convenient when I'm just cleaning up, making a few cuts around the yard or when taking a quick spin to clean up minor blockages on our trails.
I don't even consider the battery saw when doing even a half day (let alone a full day) of tree felling or storm damage cleanup out in the woods.
I spend more to buy pro-level saws to save a pound or so (in addition to the better long-term reliability and repairability). 4.5 pounds is a big difference when using a saw all day. My battery saw weighs about what a 90cc gas saw weighs. Maybe I would have considered it a form of weight training when I was 20-something. These days, weight training is not on my mind when working in the woods.
/ Battery powered chainsaw #892
Interesting comparison - thank you!
Friend of mine bought a DeWalt electric chainsaw and the first thing we noticed was the weight...
My smallest saw is a reliable 1997 Shindaiwa 360 and I use it more than my other 5 saws combined.
8.8 lbs without 16" bar, no idea how much weight bar & chain adds.
/ Battery powered chainsaw #893
Based on dirtbikes, a 2-stroke is perhaps half as efficient as a 4-stroke.
Based on real world experience, a proper sized chainsaw battery is very close to the equivalent of one tank of premix.
Inexperience and poor education breeds a lot of ignorance of electricity. Marketers have found the ignorant consumer thinks "voltage" is a measure of battery-electric tool quality. Sorry but an 80V 4Ah battery is not better than a 56V 7.5Ah, the two are roughly the same at 400Wh and 420Wh. I don't care to use my EGo 18" with 7.5Ah batteries due to weight, prefer the 5.0Ah. It has no guts with the 2.0Ah.
Agree that many really should have both gas and battery chainsaws. For trail clearing the battery tools are great because one spends a lot of time moving to a "face slapper", cutting, then moving on. Lots of start/stop. My preferred tool is an EGo hedge trimmer.
/ Battery powered chainsaw #894
For the tree farm the AP saws have exceeded all expectations.
I was able to get a little better price with a battery incentive and preferred dealer.
But yes more expensive up front.
2 battery saws replace 3 gas Stihl saws and the gas saws needed annual servicing to be ready for the intense Christmas season.
Not having to pull a rope starter thousands of times is no small benefit plus the only tree farm complaint ever was about the noise from the gas saws after dark which comes very early at Christmas.
The silent battery saws eliminated that...
/ Battery powered chainsaw #895
I got my 1 lbs estimate for a 16” bar and chain by looking at the shipping weight from a mail order place. Probably not exactly correct, but I bet it’s close. The narrow kerf bars used on most battery saws are probably a bit lighter.
/ Battery powered chainsaw #896
DEWALT 20V chainsaw and polesaw. There may be stronger ones out there, but these always did what I needed them to, and best part use the batteries I have and use often so I can buy 'tool only'. No regrets. Project Farm rated Dewalt pretty favorably.
/ Battery powered chainsaw #897
The Stihl MS 300 battery saw impresses me.
One advantage with a saw like that in MY situation is battery saws end the stress about fuel going stale and related tune-ups or mixing fresh fuel to ensure dependable performance if you are doing other work for a few weeks.
You just pick it up and it rolls.
I’d say if the Stihl MS 300 gets any better, I may try one. My first electric saw was a DeWalt 18” and I wasn’t very impressed, but it wasn’t very expensive, either AND it used my DeWalt 60V batteries.
I hear DeWalt has improved their electric saws and now offers a 20”.
I see me taking another chance on an electric 20” in the near future. My customers absolutely rave at the quiet and no exhaust smell.
/ Battery powered chainsaw #898
I've got the Atlas 80Volt from Harbor Freight and I'm well pleased with what it does. My most critical use is after storms to get the driveway open. This saw has done an excellent job of that. I don't do any more cutting then needed to be able to shove stuff off the driveway with the loader. Trying to start a gas saw after a year of sitting is a pain.
/ Battery powered chainsaw #899
What saw and battery do you have? Do you have spare batteries?
How close are you to a power source? I usually have one battery on the charger while I'm cutting, and can get a full charge in about a half hour or so. I have at least 200 or 300 yards worth of extension cords I can use if needed.
I have an older 40V Greenworks (16" or 18"), Greenworks 60V 20", and Greenworks Commercial 82V 20".
The 60V 20" and 82V 20" saws are pretty similar, although the 82V batteries have a slightly larger capacity. I'm still exploring a bit, but I like the 60V, 8Ah batteries and the 80 or 82V 4Ah, 5Ah, or 6Ah batteries. 80V and 82V batteries are similar enough to power the saw. I'll modify my saw to take both shortly.
The older 40V saw has a thinner blade, so it doesn't suck down battery juice as quickly. But the newer 20" saws really throw a pile of chips!!! But, unfortunately bigger batteries are still drained eventually. An hour or so of cutting for a larger battery? Then it is time for a brief break, change the battery, check the oil, etc.
EGO is coming up with a unique remote charging system:
It isn't going to be particularly cheap, but it would allow recharging tools on the road. Although, for that price, perhaps one is better just getting a pile of batteries.
Greenworks is putting big "suitcase batteries" in their mowers. But, I don't see a remote charging solution yet. Undoubtedly it is coming.
They do have inverters.
I tried doing this with my Ram truck & DeWalt batteries. I would keep a 60V 9 a/h or 12 a/h battery on the 60V charger and run my 60V chainsaw or weed wacker, but the batteries die pretty quick. I’d get maybe 20 min of weed wacking or 15 min of intermittent sawing done and it was time to change batteries.
Problem is, the batteries take at least 1/2 hour to charge and that means you need 3 or 4 very expensive batteries to run constantly.
I’d like to put together a cost for a Stihl MS 300, charger and 2 batteries and maybe give one a shot. Would like to see if Stihl offers a weed wacker that takes the same “500” battery as chainsaw. That would be a big plus for me as I like versatility of having one type of battery power at least 2 tools (blower, chainsaw, weed wacker, etc.)
I will probably relegate my DeWalt batteries & charger to my hand tools.
/ Battery powered chainsaw #900
My Echo often sits for 6-12 months. I’ve never had it not start on the second pull. I must be lucky
2015 Freightliner M2 106 Hawk H-1150TL Forestry Grapple Truck (A66736)
2015 Freightliner...
2015 CHEVROLET CAPRICE CAR (A66091)
2015 CHEVROLET...
Unused 2021 HLA 48in. Hydraulic Root Rake Grapple Attachment (A66734)
Unused 2021 HLA...
KOMATSU FORKLIFT (A63291)
KOMATSU FORKLIFT...
2019 Ford F-450 Knapheide Service Truck (A66736)
2019 Ford F-450...
2017 INTERNATIONAL 4300 6X2 S/A 26FT NON CDL BOX TRUCK (A67737)
2017 INTERNATIONAL...
