Battery maintainer fire
/ Battery maintainer fire #11
Wow, that really sucks but I'm glad no one was hurt! I hope that your insurance came through on this accident. Tractors can be replaced easily enough.
Slightly off topic but related.... everybody has left a battery for a cordless drill in the charger for days at a time, right?? Well, I have a DeWalt 14.4volt drill set and I had left one of the batteries in the charger to recharge. Only... I left it in there for days, and when I went to use it, the charger had pretty much melted and deformed so badly that I could hardly get the battery out.
I think the battery was no good after that too (this was several years ago) and I can't remember if it was still hot when I found it all melted, but it really scared me when I saw it. I keep the charger in the garage, right underneath the master bedroom. It had to get pretty close to catching on fire!
We had a dewalt charger pop a battery in our service truck. The truck is powered by a 3K inverter with a load sense circuit. When the charger went into float mode the inverter cycled power and started the charge cycle over again... Luckily we were standing next to the truck when it started smoking.
A friend of mine had the exact model of battery maintainer plugged into his camper to keep the batteries charged. This weekend he was walking by and smelled something like electronics getting too hot. The smell was coming from the battery minder. It was so hot, he could hardly touch it. Do not use these things near a flammable surface guys. They are not trustworthy.
Kevin
/ Battery maintainer fire #13
Present day Dewalt chargers may not have this issue, but I seem to recall that some of the older ones were not rated for inverter use - meaning the factory documentation advised against using inverters as an AC source with certain models of their chargers.
Rgds, D.
/ Battery maintainer fire #14
This is why I keep trying to warn people about the huge amount of energy stored in a lead acid battery. There should be a very low amperage fuse right at the battery clamp, just enough to allow the maintainer to do it's thing. Otherwise if you have a semiconductor failure in the device, you now have a thousand amps going through that typical low gauge, cheap thermoplastic insulated wire!
I have friends in the business of battery powered systems for utility vehicles and trucks. Every now and then some brand new service vehicle or million dollar bucket truck gets burned down to the water line on account of some failure in the DC wiring connected to all those huge batteries!!
/ Battery maintainer fire #15
Wow, that's scary. I'm going to think differently about mine now. My atv's are parked and plugged in right next to our bedroom wall.
I've already replaced one maintainer when I noticed the insulation pulled away from the wire right at the unit where the cord moves and bends.
/ Battery maintainer fire #16
They should be used only by persons who can understand the dangers and potential for disaster brought up here!
This past weekend, my FIL got a call from the folks house-sitting at his son's. The electric fence seemed to not be working. He went and got the battery. Without a thought or a care, or checking the battery electrolyte or voltage, he hooked it up to his fine-quality Harbor Freight float charger. The one with WARNINGS all over it and the box to "NOT USE ON A DISCHARGED BATTERY". This was despite having TWO regular 2/10/50 amp battery chargers on-hand.
The battery was a little group 51 salvaged out of an old Bronco II, over 6 years old. It took over a QUART of distilled water to fill it back up to normal level. To my astonishment, it took a slow charge OK and didn't blow up either the battery or the charger.
- Jay
/ Battery maintainer fire #17
Good to know. I have one of those running continuously for years now one one unused battery or another. I'm going to make sure to locate that charger in a steel open top box and locate it on something that won't burn. Thanks for the heads up
2015 SkyJack SJ86T 4x4 86ft Telescopic Boom Lift (A60352)
2015 SkyJack SJ86T...
1982 SHOP BUILT GOOSENECK 24 FT TRAILER (A58214)
1982 SHOP BUILT...
RAKE ATTACHMENT FOR MINI EXCAVATOR (A58214)
RAKE ATTACHMENT...
2021 Kubota RTV1140 4x4 Diesel Utility Cart (A59228)
2021 Kubota...
2004 Bulter Pole Trailer (A60352)
2004 Bulter Pole...
2020 Club Car Carryall 700 Gas Utility Cart (A59228)
2020 Club Car...
