Battery Info
/ Battery Info #361
That can cause it with high drain and nowhere enough time to replenish the charge.
I keep mine plugged into a 4 amp smart maintainer when the 3500 diesel is sitting! Made a plug to back feed through the 7 pin trailer socket. That way, I don't need to open or close the hood. Also, have a short pigtail with Anderson powerpole connectors on it. That way, if I need to leave in a hurry or forget to unplug, I'm not dragging maintainer down the road!
Will see how long the new set lasts with the better upkeep this time around.
Also, have block heater on smart plug that will come on at a preset temp to help crank that cold iron block over easier. Made a cover that goes over the passenger side mirror that holds the cord. This way, I see that I'm plugged in!
Wifi smart plugs really help with these tasks. Have different times set on block heater for different days, as I'm the DW's "tow truck".
Like that idea of the mirror trick!
If you don’t mind I’d like to use it!😂😂☮️✌🏻
/ Battery Info #364
That looks similar to the Weize batteries I've been buying lately. Good specs and definitely less money than most other AGMs.
Putting the 6th one purchased, an H7, in the girlfriend's new car today (new battery in a new car? It's a story in itself) and am in the process of making the cables for four H8s in the M936.
Instead of buying them through Amazon, it's cheaper to get them directly from Weize.
With 12% discount on Amazon they were same price as buying direct. Actually less, with Prime 5% discount and free ship. Being a prime member is the expensive part!🤔
/ Battery Info #366
Thinking of getting a Foxwell battery tester BT705 as per Project Farm video. Ebay has them cheaper than Amazon. Do you think the ebay ones are counterfeit? Thoughts?
/ Battery Info #368
Thanks! I've read not to purchase sparkplugs from Amazon or ebay.
/ Battery Info #369
whichever one you choose, e sure it's a sealed no maintenance battery. made mistake once with removable inspection plates, a disaster with the splash doing field work
/ Battery Info #370
Ive been buying automotive parts from ebay for over 10 years now. Never had a problem, other than a few incorrect items from time to time and that was probably as much my fault as the vendor. I've bought everything from brakes to wiper motors to alternators and transmission filters, motor mounts etc. But since ebay sells for somewhere between 50 to 75 % less than the big auto suppliers, it could be them telling you not to buy off Ebay. Just a thought from someone very happy with ebay.
HIGH END MINI GOLF CART (A58214)
HIGH END MINI GOLF...
FLARE STAND (A60736)
2017 Toyota Tundra SR5 Ext. Cab Pickup Truck (A59230)
2017 Toyota Tundra...
2010 Doyle 32ft Tender Trailer - Kubota Diesel - Stainless Steel Augers - Recently Refurbished (A61307)
2010 Doyle 32ft...
1999 John Deere 7810 (A60462)
1999 John Deere...
2016 PETERBILT 365 (A60736)
2016 PETERBILT 365...
