Battery Help
/ Battery Help #1
dj1701
Veteran Member
East Concord, NY
John Deere 4320, Kubota BX2680
The battery on my 2008 4320 finally gave up the ghost. What recommendations for replacement do you all have?
Dave
/ Battery Help #2
Dave
Wow, that is a good question. I think most are junk *compared* to a few years ago. Recently purchased "Die Hard" (2) for my tractor because that is what they had in stock. Normally, look for Interstate - ONLY because in the past I had good luck with them. Today, who knows ?
I am often perplexed to find a brand / model for anything. I have had OEM tires on a pickup go 80,000 and the next ones 20,000. Who really knows ?
Interesting to me was, the Die Hard batteries had a tag "made in Spain" on them ? So, they can manufacture these HEAVY units in Spain, transport to the US for less $ than "we" can make them here ? Wow... Guess I should not be surprised.
/ Battery Help #4
I just put new batteries in almost all our vehicles & tractors & boat last year. I went with AGM and dual purpose deepcycle/starting battery type on everything.
That means no more wet cell batteries. I couldn't find a reason to put up with corrosion & maintenance now that sealed batteries like AGMs are available for every purpose.
I chose mostly based on matching physical size or group number, Cold Cranking Amps, and terminal configuration.
The brands I chose were Odyssey, NorthStar, and Interstate Marine. They weren't the cheapest, but when I looked back over what I spent for batteries in terms of dollars per year, the cheapest batteries were never the best deal..... only the cheapest at the time.
Ordered everything online. A surprising number of places ship for free. I can't drive to town to pick up a battery for what I can get one delivered.
Only problem is how to get the old batteries to the recycler.
rScotty
/ Battery Help #5
rScotty
Probably different where you live but around here a couple junkyards actually pay money for junk batteries, think it’s 11 cents a pound next to nothing but at least you don’t have to pay to get rid of them.
/ Battery Help #6
Dave
I put the JD battery in its place. 2008 - 2022 is a pretty good testament to performance.
But poking around to find better may be worth your time and money. Good luck
/ Battery Help #7
That's almost how long the original Kubota battery - a wet cell type - lasted on the M59. From Spring of 2008 to this last Fall. Always had a charge until one day when it didn't. Unlike most batteries it didn't get weak, it just quit one day.
But during its tenure in the Kubota it required a terminal cleaning every couple of years and still managed to eat up a set of battery connectors, the entire negative lead to ground - which corroded away INSIDE the rubber insulation.
And of course the fumes ate up parts of the battery mounting box & bracketry.
I'm looking forward to the replacement AGM lasting as long and without the maintenance.
rScotty
/ Battery Help #8
That seems to be the way batteries are now. I have had several do that over the last decade. The car starts just fine and an hour later the battery is just done. I was SURE my alternator wasn’t working in my truck, nope, just a dead battery. There must be a difference in the tech that causes a cell to stop working nearly instantly.
/ Battery Help
rScotty
What is AGM?
/ Battery Help #11
AGM means Absorbed Glass Matt think a thin sheet of lead with a layer of fiberglass laying on top of it. Then roll it up. That’s one glass mat cell.
In AGM batteries (also called starved electrolyte), there is a thin ultra-fine fiberglass mat sandwiched between the plates that are saturated with battery acid to about 95% of what they can hold. This mat is then packed in between the plates and slightly compressed, then welded/soldered in place.
/ Battery Help #12
Last spring, I needed a new battery for my 2007 John Deere 2210. Ended up at Sam's. A Durocell came with a three-year full replacement warranty, whereas all of the other batteries had a one-year full replacement and a two or three-year pro rated warranty. Prices were about the same for all, regardless of label.
/ Battery Help #13
Dave
Check with Walmart
/ Battery Help #14
Dave
/ Battery Help #15
Replace with as many CA's/CCA's as will fit in the battery box. Brand name batteries with warranty bought from good retailers are the way to go. I have heard bad things about new Optima batteries so you might wanna stay away from them. Personally I just get a good quality HD lead acid battery. The last one lasted 6 winters before it started getting weak for very cold [-25/30c] starting
/ Battery Help #16
I find Walmart to have the best prices on replacement batteries (made by Johnson Controls in the U.S.) online you can get agm batteries shipped from Chrome Battery. I don't know if the have your size
/ Battery Help #17
I have had the best luck using the JD Strong Box batteries. I think they must be built for high vibration and bounce because any another brand just hasn't worked well.
/ Battery Help #18
Unions and ridiculous Minimum Wages had put the USA out of the world market.
/ Battery Help #19
I put a NAPA legend battery in my 2005, JD 4120 last winter. I had to add a 5/8” thick plywood spacer below, to get the height right, but it has been working ok.
I kept my old battery, which was about 5 years old and I purchased it from TSC. It had been cranking slow in the cold. Now that it has warmed up, I am going to put that one back in the tractor.
The NAPA legend has top and side posts. I am going to put it in my old Chevy Silverado pickup as the new “primary”. It has been cranking a little slow and still has the original, year 2000 battery, as the “camper special” auxiliary. I will trade that old year 2000 battery in on the next new one I get.
/ Battery Help
Well, I bought a JD Strongbox from my local dealer who is just down the road. They had one in stock for $155.13
Big Greenie is alive and kicking again.
