Battery Help
/ Battery Help #1
dj1701
East Concord, NY
John Deere 4320, Kubota BX2680
The battery on my 2008 4320 finally gave up the ghost. What recommendations for replacement do you all have?
Thanks
Dave
/ Battery Help #2
Thanks
Dave
Wow, that is a good question. I think most are junk *compared* to a few years ago. Recently purchased "Die Hard" (2) for my tractor because that is what they had in stock. Normally, look for Interstate - ONLY because in the past I had good luck with them. Today, who knows ?
I am often perplexed to find a brand / model for anything. I have had OEM tires on a pickup go 80,000 and the next ones 20,000. Who really knows ?
Interesting to me was, the Die Hard batteries had a tag "made in Spain" on them ? So, they can manufacture these HEAVY units in Spain, transport to the US for less $ than "we" can make them here ? Wow... Guess I should not be surprised.
/ Battery Help #4
I just put new batteries in almost all our vehicles & tractors & boat last year. I went with AGM and dual purpose deepcycle/starting battery type on everything.
That means no more wet cell batteries. I couldn't find a reason to put up with corrosion & maintenance now that sealed batteries like AGMs are available for every purpose.
I chose mostly based on matching physical size or group number, Cold Cranking Amps, and terminal configuration.
The brands I chose were Odyssey, NorthStar, and Interstate Marine. They weren't the cheapest, but when I looked back over what I spent for batteries in terms of dollars per year, the cheapest batteries were never the best deal..... only the cheapest at the time.
Ordered everything online. A surprising number of places ship for free. I can't drive to town to pick up a battery for what I can get one delivered.
Only problem is how to get the old batteries to the recycler.
rScotty
/ Battery Help #5
rScotty
Probably different where you live but around here a couple junkyards actually pay money for junk batteries, think it’s 11 cents a pound next to nothing but at least you don’t have to pay to get rid of them.
/ Battery Help #6
Thanks
Dave
I put the JD battery in its place. 2008 - 2022 is a pretty good testament to performance.
But poking around to find better may be worth your time and money. Good luck
/ Battery Help #7
That's almost how long the original Kubota battery - a wet cell type - lasted on the M59. From Spring of 2008 to this last Fall. Always had a charge until one day when it didn't. Unlike most batteries it didn't get weak, it just quit one day.
But during its tenure in the Kubota it required a terminal cleaning every couple of years and still managed to eat up a set of battery connectors, the entire negative lead to ground - which corroded away INSIDE the rubber insulation.
And of course the fumes ate up parts of the battery mounting box & bracketry.
I'm looking forward to the replacement AGM lasting as long and without the maintenance.
rScotty
/ Battery Help #8
That seems to be the way batteries are now. I have had several do that over the last decade. The car starts just fine and an hour later the battery is just done. I was SURE my alternator wasn’t working in my truck, nope, just a dead battery. There must be a difference in the tech that causes a cell to stop working nearly instantly.
/ Battery Help
rScotty
What is AGM?
HYDRAULIC THUMB FOR MINI EXCAVATOR (A58214)
HYDRAULIC THUMB...
2015 Ford F-350 4x4 Ext. Cab Service Truck (A61568)
2015 Ford F-350...
MINI KID DIRT BIKE (A56859)
MINI KID DIRT BIKE...
2014 POLAR TANK CRUDE TRAILER (A60736)
2014 POLAR TANK...
John Deere 1025R (A53317)
John Deere 1025R...
Electric Concrete Mixer (A61166)
Electric Concrete...
